Ls1 -s-10
Ls1 -s-10
whats all needed? i can get a hold of a 99 single cab shortbed pretty easy just trying to see what else would be needed. motor mounts, headers, crossmember, wiring( someone told me they make adapters so you can run the s10 stock guages) thanks in advanced also it is and auto and will go back in with one
Did you see the big-*** s10 thread at the bottom of this page?
https://ls1tech.com/forums/conversions-swaps/424515-s10-ls1ers.html
pretty easy. russel makes fittings to connect your stock fuel line to -6AN to the FPR to run stock LS1 fuel rails since the 97's are hard to find. as for headers...you dotn have to have them, I am using stocks Fbody manifolds...just have to remove the heat shields. godd luck, and it is worth the wait.
