LS-1 In A Boat........
Old Jan 11, 2007 | 03:10 PM
  #41
HandsomeBWouderful's Avatar
I saw these at a boat show a while back.
Old Jan 11, 2007 | 03:51 PM
  #42
86RedRocket's Avatar
Originally Posted by Randy_W
I like the Top Gun too! Cigarettes are sexy rides, that's for sure. If I were buying new today, I'd sure give Reggie a look before I bought anything though.
Yeah, they're both very nice boat manufacturers. I def. can't go new on one. $400k is VERY steep for me! I'd have to live in it for that kind of money and mortgage it like a house. I like the fact that you can get a 07' 47' Fountain w/the new tripple 700sci engines and nxt drives!
Old Jan 11, 2007 | 07:12 PM
  #43
Randy_W's Avatar
I bought my Donzi new in 1988, now I couldn't afford the engines and drives!
Old Jan 11, 2007 | 08:31 PM
  #44
LS1GMCTruck's Avatar
Default Those Red Engines...
Are Chevy Vortec headed engines with distributors, not LS based engine design.
Old Jan 11, 2007 | 08:40 PM
  #45
zlover129's Avatar
Where the hell did they get that intake from? Looks kick ***, i wonder if it would work with LT1 heads
Old Jan 12, 2007 | 08:36 AM
  #46
Yep, you're right. I checked out the Mastercraft website.
However, this site is advertising a 6.0 Gen IV GM motor:
http://www.indmar.com/ProductLine/Ma...Y-6/index.html
New to the 2007 engine line up, MasterCraft Power's LY-6 by Indmar is a new high-tech inboard that delivers horses and torque that rivals the big blocks in a smaller, lighter, package. Based on the new Gen IV Vortec 6000 truck engine the new LY-6 offers advanced technology called VVT (Variable Valve Timing), which allows Indmar engineers to program the LY-6's ECM to deliver an unusually long and tall power curve. It's brain is Delphi's most advanced water resistant ECM (Electronic Control Module) the MEFI-5 hardware/software system. The MEFI-5 system is custom calibrated by Indmar to provide maximum performance and drive ability. By custom calibrating the ECM to match hull design requirements and intended boat application this process allows boat and motor to perform as one seamless unit. The three-dimensional system precisely manages fuel, ignition and air. It is programmed to deliver the power skiers and wake boarder's need, plus the classic turnkey starts, unhesitating dependability and fuel efficiency that only Indmar can deliver.
Old Jan 12, 2007 | 11:50 AM
  #47
I'm waiting on some pics, but the guy has all the marine parts that came off a ls-1 malibu. He said it was a full alum. block that used the coil packs, the standard ls-1 water pump, etc. He pretty much has all the acces. from what I gathered besides the tb(uses a std. type camaro/trans am tb) and coil packs. All the ones I've seen that say ls-1 corvette engine on the internet aren't showing pics of the engine. The one's I've seen are the older malibu corvette boats that use the Calloway 383 lt-1 style engine, but not the lt-1 style intake.
Old Jan 12, 2007 | 01:40 PM
  #48
TigerWoodsJr's Avatar
it would be so cool to say I had a vette motor in my boat
Old Jan 12, 2007 | 11:23 PM
  #49
Sabre002's Avatar
I'm trying to get my Boss to let me put a LS1 in one of is Ski Nauti boats.
Old Jan 13, 2007 | 09:40 AM
  #50
Keep me updated if you don't mind if you do the project soon.
Old Jan 13, 2007 | 08:54 PM
  #51
mullenh's Avatar
the ls1 lives for the high rpm, a boat is like a limo it needs torque. save your money and put and iron motor in it. you will like it a lot more. weight is not a big issue in a boat.
Old Jan 13, 2007 | 10:21 PM
  #52
G-Body's Avatar
sawzall wielding director
Most boats run at higher RPM than cars. A car might be able to coast along at less than 2000rpm and 25hp on the highway, but most boats run over 3k at over 100hp to stay on plane.
My dads boat usually runs from 3000rpm up. At 3k it is nicely on plane and running ~35mph, if you pull back to 2500 it is barely on plane and doing about 25mph.
It all depends on your propeller/impeller size and what gear ratio your running in the lower unit/v-drive. Most production boats run under 6000, but for the high performance stuff the sky is the limit.
Old Jan 14, 2007 | 02:52 PM
  #53
Sabre002's Avatar
I think I almost have him there to let me put one in his 69 Correct Craft Mustang. I just got done putting a new 302 that I built for his 18' Donzi
Old Sep 17, 2009 | 09:18 PM
  #54
LS6Vdrive's Avatar
http://www.cassellmarine.com.au/p/85...manifolds.html
