Update on my 65 Chevy II
Old 01-19-2007, 06:19 AM
nova65ss's Avatar
I have some LS6 manifolds on the way that someone gave me. Hopefully they will be here this weekend and I can test them out. I'll let you know.
Jimmy
Old 01-19-2007, 12:35 PM
Novas Forever's Avatar
Please post if they do or do not fit. I like them but did not know if they would fit.
Old 01-20-2007, 02:49 AM
Posi12Bolt's Avatar
a 4 door! that's cool! good job!
Old 01-20-2007, 10:16 AM
nova67's Avatar
Originally Posted by 67pete
I've tried the stock 99 Camaro / TA manifolds and while the drivers side works the passenger side doesn't(using Heidts clip). Z06 didn't work either. Hedman's / Hooker's ? ...shorties will work, if thats the look you want. I cut and welded my stock passenger side manifold (double wall SS tubing) to fit. This gives a nice quiet apperence in the engine bay....
I've been doing a lot of research over the last month to start on my '67 and someone told me that Sanderson makes a header for the LS1 that would lend itself well to the Nova app. I haven't looked any further at the details, though.
Old 01-21-2007, 12:58 PM
Ox65's Avatar
Looks Great, Stay safe.
Old 01-21-2007, 03:46 PM
kdawgmfic's Avatar
I catch so much hell from my buddy back home about having two more doors. He's got a '65 Malibu and our competition of "who's gonna have the better car" has come to a compromise I think. I will out style him with modernizations such as fuel injection and he will just straight up out run my *** with raw horspower.
Old 01-21-2007, 06:29 PM
bump...concerning the LS6 manifolds.
Old 01-21-2007, 07:55 PM
nova65ss's Avatar
Nice bump, Fedex tracking says they will be here tomorrow. Not sure if I will have time to get out and try them depends on how work goes. I won't forget pics asap.
Jimmy
Old 01-22-2007, 03:37 PM
cool deal thanks
Old 01-24-2007, 08:43 PM
nova65ss's Avatar
Sorry KDawg maybe it will help you out also.
Well the passenger side didn't work lacked about an inch. Drivers side fit like it was made for it, even cleared the steering linkage. I'm not positive these are off of an LS6 but the guy told my father that is what they came from, glad I didn't have to buy them. I have seen some pics of manifolds that exit dead in the center like a shorty header does anyone know what they may be off of, or have some pictures of the different styles like the F-body etc? Thanks,
http://www.villagephotos.com/pubbrow...der_id=1816410
Old 01-25-2007, 11:09 AM
Darn. Where did the pssenger side hit? F-body manifolds wouldn't even come close to going in far enough to touch the heads.
Old 01-26-2007, 01:54 PM
  #32
nova65ss's Avatar
It hit the frame rail, you can see it in the pics where it hit.
Jimmy
Old 01-27-2007, 02:44 AM
  #33
kdawgmfic's Avatar
nova65ss which adapter plates you using?
Old 01-27-2007, 07:18 AM
  #34
nova65ss's Avatar
ATS, problem is though I welded in my own frame stands because I had a big block before. If the motor was up an inch or 1- 1/2 it would probably work. It also needs to go up anyway because it is hitting the R&P just don't want to go that high.
Jimmy
Old 01-29-2007, 09:07 AM
  #35
Thanks for posting the pictures Jimmy. That was so close. I figured that the driver's side would be the problem!
Old 01-31-2007, 01:54 PM
  #36
kdawgmfic's Avatar
I figured the same. Who's got ideas for the drivers side?
Old 02-05-2007, 11:32 PM
  #37
kdawgmfic's Avatar
bump anyone try others?
Old 03-16-2007, 12:56 PM
  #38
AlmostfastLT1's Avatar
have you guys tried the block hugers, I have seen hooker and I forgot the other company that makes them for an ls1, they are shorties.
I am doing this same project. I am building a 348-383 ci ls1 carb setup heads and cam. I bought the mustang II setup from checkered racing with the qa1 setup and rod ends etc. I am putting a built 6speed in there and the car is a 63 2door post back halfed full cage. I have no floor as I will be making out of the jegster alumin floor kit...
I will post pics up soon...
heres a pic of the front end, only problem is I have to weld in the motors mounts, and I have no idea where to place it and the angle needed for sufficient oil flow etc..
pic of front end
http://i6.ebayimg.com/01/i/04/91/b1/d0_1_b.JPG
Old 03-16-2007, 01:31 PM
  #39
I ordered a set of Ford shorties that looked like they may fit, with the LS1 flanges that is. They fit really good and cleared everything. Then I had my trusted exhaust guy look at them to see about welding the LS1 flanges in place of the Ford's and he said as soon as you cut the tubes loose from the flanges they would spring out in all directions . I asked about making the tubes near the flanges round again (the Fords are squared) and his tubing machine needed to be inserted 3 inches to work so that was a no go too. So that solution got shot down. My next try will be the Hooker LS1 shorties but I am concerned that the collector flange will hit the frame rails on my TCI clip. This is getting old but I still don't want to spend $1000 on custom made headers.
Old 03-16-2007, 02:26 PM
  #40
Here are some pictures of the LS1 in my Nova showing how little room there is with the TCI clip.
http://i175.photobucket.com/albums/w...uy/novaLS1.jpg
http://i175.photobucket.com/albums/w...passside-1.jpg
http://i175.photobucket.com/albums/w...driverside.jpg
Quick Reply: Update on my 65 Chevy II
