Custom fuel lines... quick connect flare tool?
Old Jan 15, 2007 | 09:31 AM
super_kev's Avatar
Default Custom fuel lines... quick connect flare tool?
I'm going to need to build some custom fuel lines (stock size... 3/8 & 5/16), and I was wondering if there is a tool out there that will allow me to make quick connect ends on the steel fuel line like the factory LS1 lines?
Old Jan 15, 2007 | 09:37 AM
MattP's Avatar
http://www.mastercool.com/m54.html
71475 is the one I used.
Old Jan 15, 2007 | 09:44 AM
silicone boy's Avatar
I have the mastercool device. It's so awesome. I posted this on another thread. You can get them on EBay for $250. Pricey, but I've used it several times.
http://www.torquecentral.com/showthread.php?t=39273
Old Jan 15, 2007 | 09:48 AM
super_kev's Avatar
Sweet, just what I was looking for. Thanks guys.
Old Jan 15, 2007 | 09:51 AM
MrDude_1's Avatar
if you're only making this one line, its cheaper to have a hydraulic shop do the flares.
if you're planning on making any other lines (powersteering, or bubbleflare brake lines especially...) then its well worth the money.
that little hydraulic hand-pump one they linked above is the only one i know of other then the huge pricey professional hydraulic one...
Old Jan 15, 2007 | 10:30 AM
Stu Cool's Avatar
The alternative is to purchase short nipples with the desired flare on them, then join them to conventional lines with union fittings. If you are not overly concerned with appearance or the lines are out of sight this is an inexpensive alternative. Unions do provide additional places for leaks, but if you work carefully that should not be a problem
Pat
Old Jan 15, 2007 | 01:46 PM
MrDude_1's Avatar
Pat
another alternative to that, is to have a hydraulic shop braze the two lines together.... then theres no fitting/joint to come loose....
if its painted and done well, it can look OEM ish... but often, its something you want out of sight...
Old Jan 15, 2007 | 06:02 PM
G-Body's Avatar
sawzall wielding director
I always wondered if there was a tool to make the quick connect flares. I didn`t even think of trying a hydraulic shop. I just used the quick connect ends from the junkyard and joined them by double flaring the other end and using a union. That hydraulic flare tool looks wicked cool, but its out of my price range.
Old Jan 15, 2007 | 06:09 PM
slowassta's Avatar
this is what i did...
cost me $10 or so for both fittings, works great
Old Jan 16, 2007 | 05:29 AM
69blackwidow's Avatar
i had classic tube make me a stock 69 camaro 3/8 fuel line with the male quick connect ends on both ends, then just got some high pressure fuel injection rubber hose( i think its 900 psi rated) and the female ends from junk yard, the fuel line was only 25 bucks extra and alot less trouble. no unions or brazing, less breaks in the line- less chance of leaking fuel around stuff that is hot. mike
Old Jan 16, 2007 | 10:49 PM
Rodder's Avatar
I got a new 3/8 stainless line from Ricks, cut the hose barbs off, used Swagelok compression fittings to convert to -6 AN, Russell -6 AN to quick-connect adapters at the rail and Vette filter/regulator, and Aeroquip socketless hose/fittings for the lines in-between. The part # for the Ruswell and Swagelok fittings are in the LSX into 67-69 Camaro sticky. I used the quick connects on the FPR instead of Swageloks so that I don't need to dig up new compression ferrules when I have to replace the FPR. I've used the Swagelok compression fittings on 3600psi compressed natural gas lines--I trust them more than I trust AN flares!
