EPP Ferrari 308 LS2 project car!
Old 01-18-2007, 04:49 PM
Cop Car's Avatar
make it an all around car.. youd have to do so much to get it to do good at the strip, just be fine with running 10s with the IRS and then ripping it up at the track. make sure you take that to some Ferrari meet.. dont pop the hood, run some laps and then later come back and pop the hook, or trunk, or whatever youd call it :p
Old 01-18-2007, 04:50 PM
Bimmer Tech's Avatar
Originally Posted by gnx7
That should be a cool project. You should research Mendeola transaxles. They are coming out with a street version that should handle some serious power.
http://www.mendeolaracing.com/
There are many twin turbo LSx sandrail guys running these behind them making 1000hp+ that can pop wheelies in most gears. They can take some serious abuse..... but do cost a fair penny.
Do they do transverse mounted transaxles also? The engine in the Ferrari sits sideways. I've been trying to finds a suitable tranny for my LS6 FIero for a while now...
Old 01-18-2007, 06:07 PM
TPIMarow6.6's Avatar
i would also do an all around car, drag and track...would be awsome! even tho the car only made 205hp think about what it was up against....a 170hp corvette? lol that weighed more. at the time...it was "faster" than most cars out. but i cant wait to see this thing. id personally do a single turbo setup then see some hard spooling launch videos with 315 DR's
Old 01-18-2007, 06:18 PM
Justin @ EAD Performance's Avatar
If memory serves me right the 4T65e HD used with the 5.3l LS4, has the V6 bolt pattern. I thought GM redid the LS4 block with that pattern to match the V6 trans. Therefore LS2 will not bolt to a 4T65e HD. Its been a while since I have heard this, and its been a long while since I have messed around with GM FWD, but it might be worth double checking.
Also I never knew Ferrari did transversely mounted engines.
Old 01-18-2007, 07:53 PM
firefighter's Avatar
There are some W body guys who claim to be able to build those 4T65e to take some power. The W body doesn't make the same kind of power as a LSx motor. I'll see if I can find some of the claims. I have no Idea about the bolt pattern.
Old 01-18-2007, 08:04 PM
Try these guys to maybe get some ideas on the trans they seem to be big in the W body world http://www.intense-racing.com/ also try http://www.zzperformance.com/ they are also big in the W body schtuff.
As a side note the Ferrari should be bad *** make sure you keep us up to date.
Old 01-18-2007, 10:48 PM
JRracing's Avatar
Bob, that looks pretty cool. And very fast.
Old 01-19-2007, 04:35 AM
EPP
EPP's Avatar
Thanks everyone! I'd like to make this car do everything well, which sounds like what most people here agree on. If we could get this car close to handling and running with a new Z06, then we'd have done a great job. Weight wise, it should be there. If we locate the fuel system in the front, then maybe we can keep this car from understeering.
A manual transmission would be more desirable for overall performance, but the tranny is going to be the biggest hurdle.
I'll check the links posted above. Thanks! Bob
Old 01-19-2007, 04:40 AM
EPP
EPP's Avatar
Smile
Ferrari used this configuration in the 308 and 328. Bob
Old 01-19-2007, 04:48 AM
Posi12Bolt's Avatar
that is gonna be F'n sick! I swear the LSx is an improvement in almost ANY car!!
Old 01-19-2007, 05:15 AM
EPP
EPP's Avatar
Smile
This photo may help to see how the chassis is set up. Bob
Old 01-19-2007, 05:22 AM
  #32
crafty888's Avatar
You could always put a Fiero motor in there and throw a body kit on it and make yourself a Ferrari based Fiero copy!!!
haha..
Old 01-19-2007, 07:13 AM
  #33
chuntington101's Avatar
as did lambo in some of their greats!
trany will be dificult. might be worth looking at some of the Honda stuff and see if you could get an adaptor plate to "make" it work! lol
apart form that i dont know of many FWD tranmistion that are designed to take the torque!
think the car should be manual and a true street/strip/curcit car!
thanks Chris.
Old 01-19-2007, 09:25 AM
  #34
Lincoln's Avatar
How about a Grand Prix with an LS6 and 4T65E-HD transaxle.
http://www.fastfieros.com/projects/tomkls1/tomkls1.htm
You might want to contact Loyde down at Fast Fieros. He has done a lot of work with GM and mated LSx engines with 4T65E-HD transaxles. He could save you from having to redue a lot of R and D he has already completed.
GM Performance Parts sells the hard parts to make the 4T65E-HD an extremely sturdy transaxle. There are quite a few turbo Grand Prixs well over 500 WHP.
Old 01-19-2007, 09:30 AM
  #35
Cobra4B's Avatar
Please make it a manual!
Old 01-19-2007, 11:44 AM
  #36
digitalsolo's Avatar
Originally Posted by JustDreamin
Some interesting tidbits from GMPowerTrain's Website:
4T65 & 6T70 are rated at a max of 280 ft-lbs engine torque
4T80 is rated at a max of 305 ft-lbs engine torque
My GTP is making >400 ft lbs through a mildly warmed over 4t65e-hd (blue clutches, upgraded spragues and a shift kit, along with an LSD). That's in a much heavier car with a roots blower causing the torque curve (better put, a tabletop). There are many cars making quite a bit more then that pretty reliably through built transmissions. It's not cheap by any means, but it certainly can be done. With EPP's rates, I'm sure they can swing the coin for it.
Old 01-19-2007, 02:00 PM
  #37
Cop Car's Avatar
you do know that you have to dress up like Magnum PI dont you?
Old 01-19-2007, 03:51 PM
  #38
don't forget the mustache.
Old 01-19-2007, 04:28 PM
  #39
Project GatTagO's Avatar
Received 1,441 Likes on 909 Posts
http://www.g-forcetransmissions.com/tran_gt-50.asp
Keep it transverse. Use the g-force dog ring transaxle. It will be sweet.
Also check out the various gearsets available from PPG:
http://www.ppgearbox.com.au/
I am sure one of the import transaxles can be adapted to work. Call Frank at The DriveShaft shop when you need custom half shafts.
Andrew
Old 01-19-2007, 06:50 PM
  #40
Jake@EPP's Avatar
Were planning on running a fuel cell in the front of the car, the two saddle tanks when moved would make a great place for twin turbos!
Quick Reply: EPP Ferrari 308 LS2 project car!
