Fox swap guys.......anyone running a big aluminum Ford based Radiator????
hey guys....
i'm tired of the way the factory ls1 radiator looks in the car and i'm about to buy some new fans to ditch the factory '95 elec fan. i'd like to get a nice thick aluminum one, but not sure about the right way to make the hoses work with it. any ideas short of cutting & rewelding new hose outlets would be great.
thanks,
Dave
thanks,
Dave
I have one of the Ford Racing replacement rads in my 5.0 right now. It works great, but I'm switching over to a complete F-body rad/fans/condensor setup to be able to use the stock F-body radiator hoses and to ensure the condensor matches up good. The existing rad I have has plastic tanks on the end, not aluminum so no-go on the welding. You could maybe try a big replacement/aftermarket aluminum F-body rad and go with the twin fan F-body setup if you wanted to go bigger. That way you could keep the stock F-body hoses.
Why? The factory one works better.. should be enough to cool anything you throw at it and saves weight. I switched from a big aftermarket ron davis radiator to an oem 80's corvette radiator in my rx7 and couldn't be happier.
can anyone of you guys give me a refresher on the hose sizes for the d/pass side hose fittings? i did a search but there were all kinds of irrelevant results that turned up with pages and pages to go through. thanks.
