Help me identify this.
Old Jan 24, 2007 | 10:20 PM
95 LS1 Camaro's Avatar
Default Help me identify this.
It's wired in a 98 pass compartment harness under the dash, Two wires go to the engine compartment and their is a ground and a ign power wire. What the HE double hockey sticks is this? The cricuit board goes inside the box and makes contact with the harness wires.
Old Jan 25, 2007 | 07:26 AM
Jhankinson's Avatar
Looks maybe like the VATS module to me...mine was smashed so the black plastic thing wasnt loking the same but that circuit board thing looks about the same as the guts that were in my VATS....i just tuned it out if thats what it is.
J-
Old Jan 25, 2007 | 09:30 AM
Ok, then is this found on all 98-02 f bodys? I was under the assumption that vats was controlled through the BCM and then relayed an all clear signal to the pcm. Are 98's different in this aspect? When I look up the BCM in parts it lists the same number for all years 98-02. If this is part of VATS what the heck is it actually for? I cant trace the wiring as I don't have the underhood harness?
