ls1?
Old Jan 20, 2007 | 08:36 PM
sick240's Avatar
Default ls1?
what do you think a ls1 in a 2580lb 73 240z would run in the 1/8?
Old Jan 21, 2007 | 12:06 AM
94ls1bird's Avatar
Too Fast for you
(ls1 wagon)
Old Jan 21, 2007 | 03:38 PM
sick240's Avatar
that is what i was thinking.
Old Jan 21, 2007 | 10:42 PM
94ls1bird's Avatar
post pics of the setup you have now ,and some of the rear end
Old Jan 22, 2007 | 08:01 AM
sick240's Avatar
will try to later, i need to find the disk with the pics on it, then need to learn post to get them on here. lol
Old Jan 22, 2007 | 09:16 PM
sick240's Avatar
here she is
Attached Thumbnails ls1?-100_0907.jpg   ls1?-100_0909.jpg   ls1?-100_0910.jpg   ls1?-100_0911.jpg   ls1?-100_0912.jpg
Old Jan 22, 2007 | 09:17 PM
sick240's Avatar
a few more
Attached Thumbnails ls1?-100_0913.jpg   ls1?-100_0914.jpg   ls1?-100_0915.jpg   ls1?-100_0916.jpg
Old Jan 22, 2007 | 09:20 PM
sick240's Avatar
sbc with vortech heads, gm hot cam, gluide and a brand new rear set up, 8.8 with ladder bar suspension works well for what it is.
Old Jan 22, 2007 | 09:24 PM
Cop Car's Avatar
ok, things you must know about LS1s. #1 they are overpriced. #2 buy a 6.0 LQ4 truck motor.
now, i know what you are thinking, LS1 is aluminum and you want to keep the weight down. well the cast iron block motors only weigh 70 lbs more. an LS1 will be $1500+ an LQ4 would be from $700 - $2000.
as for the answer to your question.. a LSx motor with a cam and nitrous would easily push that car into deep into the 9s. and still make 15+ mpg
Old Jan 23, 2007 | 09:00 AM
V6 Bird's Avatar
I think he could probably do the same but just not get as good of gas mileage with that setup he has.
Its a nice little toy and is very simple.
Old Jan 23, 2007 | 09:18 AM
sick240's Avatar
nice little toy, i was thinking go-cart
Old Jan 23, 2007 | 09:34 AM
Sabre002's Avatar
There is a little more then 70 pound difference from a LS1 to a LQ9 when you are talking a complete motor.
Old Jan 23, 2007 | 10:07 AM
V6 Bird's Avatar
Yea its actually in the 85-90 range.
Old Jan 23, 2007 | 10:08 AM
V6 Bird's Avatar
Go-cart is correct!
Old Jan 23, 2007 | 10:18 AM
sick240's Avatar
i'm not too worried about the weight. might be better to keep some on the front, maybe she will stay down then.
Old Jan 23, 2007 | 10:32 AM
12secSS's Avatar
Look up Dave, that240guy on here, he has a 260Z with an LS1 that runs 12.0s @ 117 and get's 25-30 MPG.
Old Jan 23, 2007 | 11:24 AM
sick240's Avatar
12.0s i would think it would run a little better than that. i have only ran 1/8 and it has gone 7.40s na and 6.40s on 150shot and that was before the rear swap, so far been to the track once and it went a 7.26 na. i would like to have the cage back in the car before i spray it again
Old Jan 23, 2007 | 01:26 PM
Cop Car's Avatar
that might be because of the diffrent accessories. im talking about the cast iron block only compared to the LS1s aluminum block. id like to see someone actualy weigh bare blocks only back to back..
Old Jan 23, 2007 | 02:50 PM
V6 Bird's Avatar
I should be able to do that if I can find a scale. I have one of each. 12.0's and 117 is turtle slow I might add.
7.2's is low 11's NA already with an old junky Vortec motor he has in their now.
Old Jan 23, 2007 | 03:26 PM
sick240's Avatar
easy, she not that bad.
