Kit Car Build with an LS1
My 19 year old son and I are tackling a kit car. Our first step was settling on a particular manufacturer and kit. Cobra replicas are far and away the most common kit but there are others. I found Factory Five Racing through the Internet and liked the look of their GTM kit: http://www.factoryfive.com/table/ffr...TM/GTMkit.html.
In addition to the looks, I was also real high on the fact that it used mostly C5 Corvette running gear. The base C5 is such a great car; a kit based on it should be terrific.
Our original plan was to tour the Factory Five shop in December, make a go/no-go decision, then buy a donor car. However, opportunity knocked in the form of a low mileage (45,000) C5 available nearby (Middleton Auto Parts, Fraser MI) for a reasonable price. The body was seriously damaged but the engine ran fine and we liked the folks at Middleton, so we bought it. Pictures attached.
It was a little strange owning the donor before we were certain we liked the kit but our back-up plan was to rebuild the C5 if we didn't like the kit. Those worries were short lived as the factory tour was great.
We're at the point of stripping the donor car. My son, in particular, is really enjoying that part of the project. I'll take some more pictures and continue the story in a bit.
Father-Son car project; great bonding tool!
Andy1
Andy1
As you suggested, it has been a great bonding experience.
Since you got the donor car already and assuming you are able to use all the parts needed from the C5 your looking to spend 35-45k. 35k being that you guys are able to do most of the work. Most expensive thing in that project is the G50 and donor car which you already got. Looks like from the pictures most of the parts needed didnt get wrecked. Not to mention if you got a heck of a deal on it, it could be less. The higher side of that figure comes from how much you are going to spend on performance mods. Then wheels come into play as well. But you can use the C5 wheels if you like.
Good luck with the project and keep us informed! If anything I have said isnt accurate please tell me, I dont care to be corrected
All my figures comes from research I have done the past 6 months or so. Hope you and your son have fun, I know you will.Casey
-Dave-
The donor price was decent but not incredible. Around $9,500. I don't remember the exact number off the top of my head. Some builders paid a few thousand less for their donors but it was worth my peace of mind to be able to start the engine and listen to it run. As it turns out, though, we're going to sell that engine and use a different one.
With 345 HP in a stock LS1 pushing just 2,200 lbs of car (dry weight), the car is supposed to scoot along pretty quickly to begin with. Quoted times are 0-60 in 3.5 seconds and the 1/4 mile in 11.6 seconds.
But with the engine pulled from the Vette and attached to an engine stand, it was just begging to be modified. We were sorting through our options--cams, heads, start over with an LS2 block, etc.--when I found an already built LS1 being advertised in the LS1 Tech Classifieds. It had fewer miles on the engine block and the build was done by a quality southeast Michigan tuner, Stenod Performance. The seller was also a good guy and we were able to find a price that worked for both of us.
I'm hoping to sell the unmodified engine and the other Vette parts that we don't need to reduce our total cost. We are planning to use the C5 wheels for starters.
Thanks for writing,
John
where are you located?
I have built 2 FFR Roadsters, someday I will build a GTM as well.
have you been to the FFCobra website? plenty of help there as there's a forum full of GTM builders.
good luck and take plenty of pictures !
Bill
As for speed, a GTM with a stock ls6 will roast a stock Z06 at a strip. The issue there is weight. The GTM is much, much lighter. On the the track (as opposed to drag racing) the GTM is more of an unknown.
