Which motor mount kit for my A-body?
Is there anyone else out there that has the motor mounts and frame mounts for the 68-72 GM A-bodies?
Thanks
The template for both the BRP and S&P Style mounts are in the Sticky.. I used them to make my plate from 1/4" steel. I just used normal hand tools to fab them.. (cutting wheels, grinder, a drill and a tap.
Use the Search and Sticky and you will find thing you need to know.. if you have specify question.. ask then.
You can also search on the rest of the A and G-Body usersID (use the Advance search) as you will get more specify info on A-Body swaps... Stealth71 is one, mind is bczee, 72chevelleSS, 72ChevelleConv.ls1. TT402LS1 and many more.
along with the Energy Suspension mounts they recommend, what else would I need to complete the swap? Just the SB chevy frame mounts?
Mainly, I'm concerned about what header will fit (I think I'll be using Hookers) and also the driveline angle being correct.
BRP claims with his kit:
Motor mounts 170.00 a pair
Trans Crossmember 185.00
Trans Mount 29.00
Frame brackets 89.00 a pair
Our $459.00 for complete kit plus S & H
The pinion angle is already engineered into the kit (3-5).
But that seems a bit pricey to me and I'd still need to buy the "clamshell" frame mounts for around $90.....
I don't mind spending the extra $ if it's worth it, but I would imagine that most of these kits have got to be built the exact same way.
The pinion angle is most likely determined by the trans crossmember, I would also imagine.
