help please.....
.For the + charging side you need to route that to the battery. usually the output from the alternator goes to the positive battery cable then to the battery.
For the fuel pressure regulator why not use a vette fuel pressure regulator/filter, its cheaper than an aftermarket regulator and has a filter included. Just search for vette regulator. It is pretty easy to hook up, there are pictures with the ports labeled in at least a few threads.
