thirdgens and ls1s
Old Feb 27, 2007 | 10:40 AM
97bigb's Avatar
Default thirdgens and ls1s
What has to change to put a ls1 in a 1992 camaro? i have heard that the k member will need to be changed. what else?
Old Feb 27, 2007 | 11:59 AM
bczee's Avatar
Trans x-member, depending on what trans you are going to use. Mods to the fuel and cooling systems.. A/C?
Check out Hanks 3rd Gen web site. they have everything you need or they can help.
Old Feb 27, 2007 | 05:02 PM
badjuju342's Avatar
Deranged Rat Fink
Have I got a deal for you!
https://ls1tech.com/forums/chevrolet-camaro-1967-2002/411887-official-swap-thread-my-camaro-56k-run.html
Everything you wanted to know about a thirdgen/LS1 swap but were afraid to ask....
Old Feb 27, 2007 | 05:12 PM
G-Body's Avatar
sawzall wielding director
/\ /\ 56k warning lots of pics in that thread
Old Feb 28, 2007 | 08:55 AM
ghettocruiser's Avatar
worth the wait though..its a good thread. Also dont forget to check out thirdgen.org ... lots of useful info on there.
Justin
Old Mar 2, 2007 | 10:08 AM
97bigb's Avatar
what is the cheapest you could get an ls1 for with wiring and computer to operate with a thirdgen.....I have heard some of the wiring is not needed?
Old Mar 2, 2007 | 01:03 PM
StevenK's Avatar
Someone needs to learn to use the search button.
Read the stickies here and on thirdgen.org (motorswap/lsx/ltx section)
Then search both sites for things that are not clear.
Then come and ask generic questions ;-)
edit: ...and take the plunge, you will thank yourself later
Old Mar 2, 2007 | 01:24 PM
BTW... "Cheap" and "LS1 swap into a thirdgen" dont usually go together. But I guess that depends on your definition of cheap...
And definetly do some more research. There is more than enough info on this site as well as thirdgen.org to do an LS1 swap with your eyes closed.
J.
Old Mar 2, 2007 | 04:56 PM
crainholio's Avatar
Your research methodology has to change, for starters...
Old Mar 2, 2007 | 04:59 PM
Project GatTagO's Avatar
Who the hell has 56K anymore?
Andrew
Old Mar 2, 2007 | 05:08 PM
G-Body's Avatar
/\ I do
Old Mar 2, 2007 | 06:00 PM
LS1-IROC's Avatar
J.
Amen to that bro! I'm creeping in on $10K but it's ready to fire up!
Old Mar 3, 2007 | 09:28 AM
92zcamaroperson's Avatar
yeah...you can do it cheap...~3000 dollars as long as you keep it a completely stock motor and use manifolds for the exhaust and budget and look for the best deals....thats what i was going to do....1000 dollars ago....
Old Mar 3, 2007 | 02:40 PM
I stand firm in my belief that getting a donor car is the way to go. Because not only will you find a ton of stuff on the donor car that you can use, but you can sell off what you dont and make some dough.
Im at around $10-$15 grand...But I re-did the whole car. Suspension and all...
Justin
Old Mar 3, 2007 | 03:06 PM
LS1-IROC's Avatar
Yeah, I would agree with the donor car deal....I would have went that way but I decided I wanted all new parts so I bought a crate motor and T56.....that added alot to my cost.
Old Mar 3, 2007 | 04:12 PM
6L.IROC-Z's Avatar
I am still under $10,000 with the price of the car. Being a machinist and having a welder has helped out a lot, built my own headers and all mounts. I have more in my carb,intake and ign. box than I did my 6.0L long block. I have more time than money so i was able to wait on deals. Depending on your time line and condition of the car when you start the project you can have a running driving 3rd gen LS1 swap for $10-$12 grand. I think it was worth every penny.
Old Mar 4, 2007 | 02:24 PM
Posi12Bolt's Avatar
/\ I do
I live in the country... 56k is all thats available, unless I wanna spend dough on the satelite...
Old Mar 4, 2007 | 06:42 PM
StngKlr's Avatar
https://ls1tech.com/forums/showthread.php?t=411887
Just in case badjuju342's thread dosent cover it all, here's mine from 3 years ago. http://www.thirdgen.org/techboard/en...-89rs-ls1.html
More to read.
