flywheel for 5.3
Andrew
Andrew
Any LS1 flywheel will bolt up.
For a 10 spline disk, check out aftermarket clutch manufacturers. I found 1 that lists the same PN for 26 spline BBC disk and LS disk. They also list a 10 spline disk that works with the BBC pressure plate. That 10 spline should work with the LS pressure plate.
I already bought brackets to move the A/C high. I bought 350 cups and mounts with plates to set back motor 1 inch. please help. I have a flywheel from ebay but now fear I will not have the offset of .40 that is needed. How do I know? One more thing. Any videos on how to connect the 4 wires set up to my 1989 chevy silverado ???
