LS1 swapping into G-body
In any case I would just like a quick run down of the process and any suggestions. My uncle and I would be doing the work ourselves, He has been working with cars for almost 30 years and he is able to fabricate, although i admit most of his work is done on the body of cars. How long does a swap normally take you guys? Thanks for any input at all, i really want to treat my baby right.
Id say the ones you find on ebay should be alright. There is a seller with the name Fparts who has good feedback and sells a lot of LS1s.
Personally I'm probably going to build mine starting with a 6.0L Iron block and gather parts and put everything together myself. This will *probably* turn out to be more expensive than just buying the stock LS1 swap but I'll end up with a faster car in the end.
i just got my engine for my 80 bu today.. and the wireing seems daunting.. but i guess ill have to figure it out..
John`s site is one that you want to read, it is the bible of swapping a LSx into a a/g-body and has a lot of info that is valuable no matter what you are putting the engine into. You may also want to read this thread https://ls1tech.com/forums/showthrea...ghlight=camino it has some info specific to El Caminos. If you are looking for wiring info check out the FAQ sticky. There are also a bunch of pictures of my swap on my f-quick account(link in my sig).
Time for the swap is something that varies greatly with how motivated and prepared you are. I did my swap in 2 weeks (well 3 weeks, but I went on vacation the middle week and did nothing to the car), by the end of the second week the car was running but not finnished. I didn`t have a speedo, tach, temp gauge, gearshift indicator, the intake consisted of flexible dryer duct.....etc but the car was again driveable. I had a lot of motivation though since it is my only car and school started the week after I had the car running. There were also a lot of 16-18 hour days in those 2 weeks. I would say that a month would be a reasonable goal, but there are people who have spent 6+ months before they had a running car. It all depends on how much research you do to prepare, and how often you are going to work on it. I was working on my swap every day for those 2 weeks.
As far as the engine goes im hoping to do away with the cats. i want to know what im doing to the engine while its out of the car. i think i need about 400 flywheel horsepower to get as much power to wheels as i want, right? the LS1 can do this with moderate bolt on's right? the selling point for my financing is better gas mileage (parents).
I'm making a power point, and trying to explain a budget to them. I'm new to the LS1, and what it can do. Thanks for any help guys.
. As for the rear you can run the stock rear if its in good shape. The 8.5" grand national rear ends are a bolt in (the driveshaft is 1" shorter than if it was a 7.5" rear, but everything else bolts up) and they are a very strong rear end, but they are also costly (average $500-800). I know there are at least a few EC`s with LSx engines and the factory 7.5" rears, it all depends how much you beat on it. EC` are traction limited with street tires, on dry pavement I start spinning the tires at ~1/4 throttle so that limits the stress on the rear end. If you run street tires you probably won`t have any problems, but if you put slicks on and start launching the car you may break the rear end.
