what are the dimensions of the ls1 engine?
Old Mar 3, 2007 | 10:04 AM
Houston999's Avatar
Default what are the dimensions of the ls1 engine?
what are the dimensions of the ls1 engine? planing to do a swap in a car, I know that the car takes 302 and 351 ford engines does the ls1 has smaller dimensions.
Old Mar 3, 2007 | 10:24 AM
bczee's Avatar
This has been asked many times in this forum.. try a Search.. not sure what the Ford Engine Dimension are. What car are you going to swap into?
But from Flywheel to tip of Water pump = 28.75", Width from outer edgle of heads = 24.75".
Old Mar 3, 2007 | 11:20 AM
Houston999's Avatar
it is the coupe cobra from factory five.
Old Mar 3, 2007 | 11:35 AM
THE_SUPRA's Avatar
you will have no problems fitting an ls1 in there...
Old Mar 3, 2007 | 12:26 PM
Houston999's Avatar
http://www.factoryfive.com/table/ffr...pegallery.html
Old Mar 3, 2007 | 03:34 PM
Bo185's Avatar
This is the truck engines, so the intake is higher and the oil pan is lower but it is the same size block.
Old Mar 3, 2007 | 04:49 PM
JD_AMG's Avatar
