Carburated LS1
Old Mar 7, 2007 | 07:59 PM
6L.IROC-Z's Avatar
Wink
Yeah, where did you get that cover?
Old Mar 7, 2007 | 09:20 PM
PRAY HRD's Avatar
uh oh....cat may be out of the bag now!
Old Mar 7, 2007 | 10:10 PM
bygblok's Avatar
don't know and don't care but "if" I can get the measurements for it I'll have the guys in the sheetmetal shop fab me up one of my own!!
Old Mar 8, 2007 | 08:48 AM
PRAY HRD's Avatar
lol. first off, why respond if you don't care.
second off.....how much more of a hint do you need! just messin' with ya.
Old Mar 8, 2007 | 09:57 AM
cmdeoro's Avatar
Ok so do you know where I can find a cheap t56? As far as the t5 goes I think I'm calling it the wrong thing. What is the five speed that is in the ** IROC.
Old Mar 8, 2007 | 01:08 PM
NemeSS's Avatar
correct that is a t5, the 3rd gen trans. its joke for hi perf. builds
unless u are using a gforce built t5, but thats a racing trans is well beyond
3k$.
t56 is 6 spd. from 4th gen f bodies,
i dont know bout cheep, t56 price range from 1000$-1500$ for stocker
or rebuilt ones, but well worth the $ imo
Old Mar 8, 2007 | 03:34 PM
cmdeoro's Avatar
Cool thanks for the help
Old Mar 8, 2007 | 07:55 PM
PRAY HRD's Avatar
ok, that makes more sence now, i thought you meant a ford based t5 trans. well, +1 on the 6 speed because it can be made strong, is stronger to begin with, plus you can run a steep ring gear and still drive it around at non-rediculous rpm's.
Old Mar 11, 2007 | 11:45 PM
FOUROHSICKS's Avatar
Originally Posted by Darracq
I have a hesitation when i give a lot of gas, it pops back though the carb and then goes, I think i need a bigger squirter, anyone a good carb tuner?
that is called a lean backfire.if it bogs it is too rich.try adjusting the little plastic cam on the throttle to the 2 position.if that don't work call back
Old Mar 12, 2007 | 09:43 AM
Darracq's Avatar
Put new plugs in it and it went away but i am real lean now, plugs white and spark knocking. I am going to jet it up and see if that takes care of it.
