transmission -an fittings???help
Old Mar 11, 2007 | 08:42 PM
s10_ls1's Avatar
Default transmission -an fittings???help
i am cam and convertering my truck and figure i would put a ranny cooler on as well what -an fittings is everyone useing the cooler i want to use has male 6-an outlets on it so would like to use -6an fittings in transmisson any help would be greatly appreciated..thanks
Old Mar 12, 2007 | 05:15 AM
kossuth's Avatar
The fittings in the tranny itself I believe are 1/4" pipe thread, or at least they were on the caprice I just helped a friend of mine convert to a LS1. You would need adaptors to convert from there.
Old Mar 12, 2007 | 06:03 AM
s10_ls1's Avatar
thanks for the info
Old Mar 12, 2007 | 07:24 AM
tirefryin_s10's Avatar
as far as i know all of the gm autos are 1/4 npt so just get a simple 1/4npt x -6an and you will be set
Old Mar 12, 2007 | 08:06 AM
'JustDreamin''s Avatar
Not all GM autos are 1/4" NPT
One of the fittings (I think its the return) on the late model (I think starting in '99 or so) 4L80E is special, has an extended nipple to feed lube to the innards of the trans.
So, it depends upon what you're working on.
'JustDreamin'
Old Mar 12, 2007 | 05:59 PM
s10_ls1's Avatar
my bad guys i didnt post what tranny i have i am working with a 4l60e..sorry about that
Old Mar 12, 2007 | 07:59 PM
wkdivr's Avatar
Here's what I did for mine. Aeroquip Socketless push on hose;-6 fittings
I used Jiffy tite Quick Disconnect fittings, and some heat insulating sleeve to protect the lines from the heat of the headers. After I'm sure there's no leaks, or problems, I'll pull the sleeve all the way up to the 90 fitting on the tranny
Old Mar 13, 2007 | 11:49 AM
TOOSLO5's Avatar
What JustDreamin stated about the 4L80 fitting is correct. The back fitting does have a tube that sticks out about 1 1/2". I just pulled the fitting from my trans yesterday since I need some 90 degree fittings to clear my trans tunnel.
