LQ4/4L60E to 71 A-body info needed
This is my first post on LS1Tech! I have a 71 Cutlass Supreme with a built 355 SB Olds. I am a die-hard Oldsmobile guy, but the prices and lack of a aftermarket have driven me insane. So too remedy this I am acquiring a LQ4/4L60E dropout complete from a pick-up. I am knowledgeable about the electrical requirements, however the actual fitting of the engine is greek to me. I would like this to be a very straight forward swap, nothing exotic. I planned on using Trans-dapt LS1 mounts on the block and standard Chevelle SBC frame mounts. 2 questions arise from this: I will need a modified F-body oil pan correct? Secondly, will the trans tunnel require any modification and will the cross member have to move? Next question is the fuel system: I have a sumped stock tank in the car right now, if i run -06 from the sump into a EFI inline pump then up to a bypass regulator then on to the fuel rail will this be a good functioning system?
The stock fuel rail, if it is a return style, should have a built in vacuum referenced regulator.
Hope this helps. There's alot of helpful info in the stickys located at the top of this section, and several swaps have been done in Chevelles and are easily found by using the search function. There's some details in the link located in my signature as well. Good luck!
Sorry that was dumb...I did have to modify my transmission crossmember and most likely you will have to as well with the 4L60. Since my 4L80 fit without much modification to the trans tunnel, I doubt it would be an issue with a 4L60, but that depends if there are any major differences with a cutlass, and the driveline angle that you end up with, depending on the motor mounts and trans mouting.
