Headers for LS7 in a first gen Camaro
My LS7 is mounted on the higher big block mounts. The car has a 21st Century C5 subframe on it, and to maintain the rack placement, the engine had to be raised from the normal position due to the oil lines cast into the pan. The subframe also is mounted on the shorter body mounts, which compounds the problem even further.
Basically, my problem is floor pan clearance, so I guess what I am wondering is if anybody has any ideas for what I can do header wise. I think the big block mounts put the engine about 3/4" higher than the small block ones, but I am not really sure. The body mounts put the engine about another 1/2" higher relative to the floor. I am willing to modify headers to fit, but at the same time I don't want to have to waste time and money on something that won't work.
Too bad I have a GTO instead of an LS1 f-body, as this would be the perfect excuse to buy headers.
I am pretty sure the GTO headers won't fit though.
Edit: Gen3Benz, just since you asked here's a little teaser from when we test fit the motor in the car for the first time. I'll to throw some more resent pics online a little later.
ok...its later.
That subframe is sweet.
I checked out 21st century street machines website looking for the price and......if you have to ask you cant afford it!
This is the four link from Detroit Speed and Engineering, it's hooked up to a narrowed Currie 9-inch:
Here are the mods in the trunk for the suspension, along with minitubs also from DSE. This setups will allow us to run 335s in the back:
Then:
Now, and don't mind the rat's nest of wires, it's still a work in progress:
Here are the C6 Z06 brakes (the car has more vette parts on it that Camaro parts, lol). 14 in rotors mean 18 in wheels:
We're still waiting on the wheels, so I don't have any pictures of those yet. They are 18 in Fikses, and they are just going to make the car look awesome. The tires will be 275s in front and 335s in back, so the thing ought to stick to the road. You couldn't see in these pics, but the car a has T56 with the Viper output shaft with MN6 ratios. Hopefully, in the next month or two, the car will really come together. The goal is to have it on the road by the end of June for the prime driving weather here in Phoenix.
Seriously, the goal is to drive to Hot August Nights in Reno in the first week of August. The Best V8 Stories One Small Block at Time
Not sure if they will fit with your subframe, but you might as well ask.
Mark Stielow ran them on his LS7 '69 but he is running a stock subframe: http://www.lateral-g.net/stielow/
