Fan CFM to cool LS1
I searched and couldn't find what fan CFM rating would be needed to cool a Ls1? It's in a 76 Datsun 280Z and there's not enough room to run the dual F-body fans on my rad. Planning on using a single 16 or 18" with a custom shroud. I also want to trigger it through the PCM and with my Vintage Air trinary switch. Any suggestions? I plan on having Speartech modify my '01 harness.
Thanks, Martin
Thanks, Martin
but still ... the more air it moves the more work (energy) required to do the job.
is it newton 2nd law of motion that says "energy can neither be created nor destroyed, it can only change state".
its kinda like how with a specific drag coefficient and weight you require x number of horspower to reach y number of mph. air is always going to have a given drag, we can't modify the air (i dont think).
as far as motor efficiency a shaded pole motor has very little torque vs. a split capacitor motor, but a split capacitor motor uses a lot more energy and thus can do more work.
and if you have a fan that is designed poorly and does not move as much air, there will be less drag on it, thereby drawing less amps.
so cfm vs. amp draw are directly related.
and yes the efficency of motors today vs. the archaic motors of the say the 1950's has greatly improved, but todays motors are basically the same as far as materials=efficiency the only major diff being for example a spal motor may have more windings, drawing more current to move more air.
Thanks, Martin
