Wiring help
Old Mar 24, 2007 | 10:16 AM
prdtr15's Avatar
Default Wiring help
Im using a 98 pcm in combo with motor and 6 speed trans. i am trying to go threw and eliminate wiring i dont need before i start mock up in he car. I have some questions on the wire, if i need them and why, thanks
Transmission range signal A
Transmission range signal B
Skip shift solenoid
1-2 shift solenoid
Skip shift lamp control
Reverse inhibit soleniod control
Trans signal range C
TCC brake signal switch
ECT sensor
Trans Fluid pressure control (low and high)
Thanks
Old Mar 24, 2007 | 01:37 PM
Jones'n's Avatar
Theo nly things I see that you are gonna need are:
Reverse inhibit - goes to 6 speed Reverse lockout. Computer controls the solenoid and I believe it'll lock you out of reverse if this isn't connected.
ECT Sensor - Engine Coolant Temp. The computer will want to know the engine coolant temperature in order to run properly.
Old Mar 24, 2007 | 02:50 PM
prdtr15's Avatar
thanks, not sure y i typed the coolant temp sensor in there.
