header help
Old Apr 3, 2007 | 02:49 AM
SMAX's Avatar
Default header help
i tried the search, but it doesnt work and i dug through as many sticky pages as i could bear. i am looking at putting an ls1 into a 65 el camino and i am wondering if there are headers that will work for this application?
Old Apr 3, 2007 | 12:27 PM
Novas Forever's Avatar
This a a challenge for us. Check Patriot and Hedman, Hooker also has some for a Camaro. I still have not found any for my Chevy II but am still looking. You may also be able to use the new Z06 manifolds that flow really well.
Old Apr 3, 2007 | 02:26 PM
SMAX's Avatar
well i found these and i think they will work, but not sure?
http://store.summitracing.com/partde...5&autoview=sku
Old Apr 3, 2007 | 03:08 PM
Those are the ones that are talked about on this site. Not enough room in my car but they look good to me.
Old Apr 3, 2007 | 03:20 PM
bczee's Avatar
Yeah.. those are marketed for Chevelles.. Hookers are about the only mass marketed Headers.. S&P Markets some. Other than that.. your into the custom or kits.
Old Apr 3, 2007 | 03:50 PM
SMAX's Avatar
anyone know if the hookers will work? isnt the chevelle front chassis the same as the el camino?
Old Apr 3, 2007 | 04:12 PM
If they are for a Chevelle they will fit your El Camino.
Old Apr 3, 2007 | 04:19 PM
bczee's Avatar
Yes. Chevelle and El's are.
In comparing how the LS1 headers will fit.. If they built anything like a sbc headers (as far as fitting and clearance).. They will be close, but most likely hang a bit low for a Camaro.
If you look at some of the manufactors catalogs for headers (ie.hooker) or use Summitracing, then use the Application tab for some Hooker SBC headers (like #2451), you will find many year/models that they can be used on for the same listing. For a 1st gen camaro, 67-69 Nova and simular year Chevelles. They sometime list the same part number. So, if you go by that reasoning.. with a little help (Hammer ?), it should fit. But this is only taking a guess with that reasoning. Try and find someone who has tried those Chevelle ones on a camaro.
