Oil filter thread size
Old Apr 5, 2007 | 10:19 PM
76LQ9TA's Avatar
Default Oil filter thread size
I have a 2002 LQ9 engine that used a UPF44 oil filter. I swapped the deep truck pan for the 98-02 camaro pan. When I went to install the oil filter, the threads on the camaro pan are a larger diameter. I thought all of the LS engines used the same filter. Has anyone seen this on the pans from GM? I ordered the parts from an out of state dealer. I looked at rockauto and they list a pf46 filter for both 02 escalade and 02 camaro.
Old Apr 5, 2007 | 11:04 PM
Derek 357i's Avatar
Having same problem. None of the LS1 oil filters are fitting on my F Body pan.
Old Apr 5, 2007 | 11:44 PM
01WS6/tamu's Avatar
Same here
Old Apr 6, 2007 | 01:24 PM
76LQ9TA's Avatar
After going to the dealer, I was told that the new 98-02 pans from GM are sold with the boss to use the pf48 filters that come on the 07 engines. It looks like the filters have an anti-drainback valve in them. I was also told that I could switch the bosses out from my truck pan so I can use the upf44 filters I already have. I am trying to find out if they make an ultragaurd gold version of the new pf48 filter.
Old May 25, 2016 | 01:26 PM
Grip's Avatar
http://www.improvedracing.com/tech/l...-reference.php
All NEW GM pans have the PF48 filter boss.
Fram XG10060
Old Jun 5, 2016 | 01:53 PM
BennyB's Avatar
Hate to bump an old thread, but I am having the same issue. I bought a new LS1 oil pan for my new shortblock and I bought the wix extended oil filter pn51522 for a little more oil capacity and is what I used on my old motor and it will not thread on the new pan. Any info out there on what I can/ should use? I'd like to stick with wix oil filter
Casting p/n on pan is 12558899 and GM p/n 12628771
Old Jun 5, 2016 | 02:08 PM
BennyB's Avatar
Fram XG10060
Looks like you may have answered my question. I'm guessing this pan has the new oil filter boss then... Looks like I'll be returning this oil filter
