Fuel line on R or L side of frame?
Mike
The fuel line comes to the fuel rail on the driver's side. IMO, the best thing to do is have a baffled tank with an in tank pump, then have a pressure regulator near the pump. The 99+ Corvette filter/Regulator is cheap and works well. Then run a single line up the driver's side of the car. There is more info on the pressure reg and plumbing in the FAQ sticky at the top of the page. Great project you are starting, should fly!
Pat
I did this on my swap as the original fuel line was on the passenger side already and I didn't feel like rerouting the hard line.
Pat, I'm using a 20 gal Crown Victoria tank, a '90 Mustang in tank pump, and the semi-returnless system from a '90-'93 Vette (Napa #FIL3737). Seems to be the hot hot-rod setup and I liked the idea of running only one line forward.
Mike
