LS2 Jet Boat
Check out the avatar in his posts.... I wonder if that's his boat standing on the jet
770, The LSx series would have enough torque depending on what you are looking for. There were some jets that came from the factory with SBC power. Usually a SBC will push a 18-20ft boat to 55mph, with a jet they are very efficient up to ~45mph on both fuel and HP, it takes a little more HP and fuel to hit 55, and from 55 up it is diminishing returns from the HP you put in and the fuel consumption starts increasing very fast. You can also change the impeller size to allow the engine to rev higher if you don`t have the torque down low. I attached a HP/RPM impeller chart.
Those guys are a bit crazy, but I LIKE IT!
I loved the quality of the fabrication. Boat construction details (like built in hand grips) were very good.
One of my favorite things that SpeedVision used to carry was JetBoat Sprint Racing. Sadly, it doesn't seem to get picked up anymore. Neither does the Austrailian touring car series, which was a real pick-me-up in the middle of winter when nobody here is racing. Instead, they replaced it with hours upon hours of boring overpriced car auctions. What thrilling TV. (End Rant)
Duramax in a jetboat sounds interesting. I'm sure you could figure out how to make that work. Probably need a pump designed for that rpm / power range, which might be a little bit of work. Not sure what that diesel weighs, but I bet it's not all that light. Might be a bit much for a small boat. Would be interesting though.
'JustDreamin'
Ken
Plot of power curve (Pickups): http://media.gm.com/us/powertrain/en...ilveradoHD.pdf
Looks like a DuraMax weighs somewhere around 840lbs. http://www.isuzu.co.jp/world/corpora...ne/lineup.html Not sure if that's dry or wet weight.
'JustDreamin'
