another turbocharged ls1/sn95 mustang build....tell me what you think
the second set of pics are c6 acc.
im running truck acc. havent realy got that far yet, think the alt. might be hanging out of the hoold. if it does, i am going to probally build my own alt bracket.
Originally Posted by tirefryin_s10
I have the stainless flanges for the manifolds brand new i will sell you if you like?
ok, i understand which ones you have now. how much for them??? shoot me a pm
well, its been a while since i gave an update on my build. because i have been working on my car alot. i have a big chunk of the car done. i upgraded turbos from a mpt70 to a borg warner s400. here is some comparison pics of the two. the s400 weighs 45 lbs!!!!!
i have all the fuel system done. have the intercooler mounted. motor is wired up, power windows work, headlights work, battery kill switch done, radiator and fan setup done, i dont know probally more
ordered all the turbo plumbing the other day, but it will be a few days before i get it cause they didnt have the 5" in stock for the down pipe.
i have to pull the motor back out tommorrow and put the gaskets back on everything and put the converter in and i will pe ready to put some fuel in it and fire it up. woo hooo, cant wait.
im going to try and get the dzus fasteners on the hood this week too. im running a stock cobra hood, but couldnt find a pin on version so i made my own. took a bolt on and cut the bottom skin off of it and cleaned it up. its going to work great i think. have tons of clearance on the truck altenator and the tb elbow. im makeing my own elbow out of a 1/2 inch carb spacer and some aluminum. paid out all the money for a nice tig, need to use it. lol
#32
yeah, i have already had a bunch of them bitch me out at the chassis shop when it was getting the cage and stuff done. lol...............
i have quite a bit more done on it since i posted pics last, i have most of the turbo stuff done, car wiring still has a little to go, and need to mount the hood on it.getting closer. havent had much time to work on it lately though, been working too much. but, have to pay for all this **** somehow. i will try and post some pics tonight.
#36
looks sick! what are you doing for the turbo mounting? Did you fab up a mounting plate/bracket and weld or bolt it to the chassis where it sits? Curious because I'm probably going to run that same turbo and know I will be breaking things if I just let it hang on the hotside rather than brace it.
Thanks -
Thanks -
#37
Thanks -
Thanks -
there is a peice of angle iron welded to the frame that the turbo bolts to. yeah, that thing weighs exactly 45 lbs!!!!!!!
