Dipstick and Pan info
Old Apr 20, 2007 | 01:01 PM
Jhankinson's Avatar
Default Dipstick and Pan info
I have been using for a while...an Fbody dipstick and a truck pan on my swap. Is there any real problem with it. I know the truck comes up a different route...but really what dif does it make inside the pan. So really is it ok to use it for oil level. As the oil level wil be just as far from the windage tray as it is on the fbody pan. Hope it will be ok. Any info would help.
Old Apr 20, 2007 | 05:39 PM
s10-den's Avatar
I dont see a problem other than it might not read right.easy way to check that is do an oil change and when you know its full, check the dipstick...but you all ready knew that....ha
