Finally got wheels and finished the LS1 Mustang
Took the car to the track and ran it on a 100 shot. The engine has an MS3 cam, TH400 w/3800 stall and headers. I have a UPR pro series suspension with AJE tubular K-member and A-arms. First pass let off at 1000' getting used to it and it ran 10.60@121 on a 1.52 60' no nitrous on launch. Second and third pass both times the car wouldnt hook and went 10.8@132 on 1.9 60' nitrous launches. There are still some bugs to work out and I plan on increasing the shot and tweaking the suspension as well. As usual once the sun went down the track went away so the only really good pass was the one that wasnt complete. I am hoping to get a 10.4/10.3 with a 100 shot before I increase it to a 200 shot and shoot for 9's. the weight of the car was 2700 lbs w/o driver although I dont know the true accuracy of the scale.
WOW...that car looks sick man. I would love to see that in person some time...and also Whistlers car. I am seriously thinking of doing a Notch swap as soon as my S10 is all worked out. That car is sure one fine swap!!
what was in it befor?you say its slower on motor.I used to live in Orlando and the track was my home away from home.Any of you know Greg and another guy named David?Both have camaros ,one a green 69 and the other a white 83ish?Both run in the 8's! and drive them everywhere down there.
posted some new info and pics...by the way Chris if you read this I may need some help tweaking the suspension so I will probably give you a call for help on that.
They are 351 ford headers with GM flanges and a few of the tubes were bent to work in my application. MY best 1/8 time was when I didnt spray until about the 100' mark and it went 6.7@104....
They are 351 ford headers with GM flanges and a few of the tubes were bent to work in my application. MY best 1/8 time was when I didnt spray until about the 100' mark and it went 6.7@104 on a 100 shot....
