LS1 swap to LT1 coolant Temp sensor wire?
? I know there is a yellow wire on blue connector at pcm that says "pcm signal out" but where does it come into the inside of the car? Don't think the LS1 c220/c230 connectors have it anywhere there?Thanks.
I'd rather not install lt1 temp sensor and feed inside rather use the stock ls1 sensor.
