Fuel pressure problem
Old May 2, 2007 | 03:54 AM
daddykamp's Avatar
Default Fuel pressure problem
I did the 3.4L to ls1 swap in a 94 camaro and im only getting about 40 psi of fuel pressure and i need 60. I was thinkin that i just needed to change the fuel pump to an ls1 fuel pump but i was told they were all the same and i needed an adjustable regulator, but im not sure what regulator i should get? Would an lt1 adjustable regulator work, if so wheres a good place to get one?TIA
Old May 2, 2007 | 04:53 AM
LS1MCSS's Avatar
You would be better off with a bigger pump. That pump wasn't designed to put out the volumn of fuel that the LS1 might need.
Old May 2, 2007 | 08:24 AM
mattmartindrift's Avatar
any pump should flow enough at idle. When the injectors reach the higher duty cycles is when the pump struggles to maintain adequate flow
Old May 2, 2007 | 09:06 AM
Steve1969LS1's Avatar
Just get a factory pump and the Corvette filter/regulartor from GM. It's pre-set at 58 psi as I recall.
And yes, you need almost 60 psi. 40 will run but will run like crud.
Old May 2, 2007 | 04:04 PM
G-Body's Avatar
sawzall wielding director
What are you currently running for a regulator? The single feed LS1 fuel rails do not have a regulator, as the regulator on those cars was in the tank. Are you trying to re-use the v6 reg?
The vette filter/reg would be a great option.
