MSD Ignition problems
Old May 4, 2007 | 06:01 PM
paco1112's Avatar
Default MSD Ignition problems
I just put in a LS364 in a 1967 camaro with a MSD ignition 6LS-2 controller. MSD has included several plug in chips for advance timing control. This controller also has the ability to map a timing advance curve with MSD’s easy-to-use Pro-Data+ soft ware via a lap top computer. Does anyone have any experience with this? Is it worth my time to use the so???are or to stick with the plug in chips?
Old May 4, 2007 | 07:36 PM
Darracq's Avatar
I like to mess with timing curves so the 6010 box works best for me, Right now i have mine sets at 32 from 1200 rpm to red liine, runs real good there, If you ever want to run nitrous then you would want the adjustable box.
