question for Edelbrock/msd carb conversion
Old May 5, 2007 | 02:59 AM
chris-m's Avatar
Default question for Edelbrock/msd carb conversion
to anyone who is already running the edelbrock #7118 manifold and msd ignition unit. (the msd unit that comes as part of the complete package with manifold).
does the msd ignition unit have an adjustable rev limiter? i have emailed MSD (twice without reply) and also edelbrock (also without an answer).
I understand the msd unit that comes with the package is a more basic version anyway that may not hook up to a laptop for adjustment of the ign curves, relying on the timing pills only, but i'd have thought it came with a rev limiter in place?
I'd also hoped that MSD would answer technical email questions but there you go!
thanks if anyone can help.
Old May 5, 2007 | 10:50 AM
jay_lt4's Avatar
i have the first of the msd/edelbrock box's and i can tell you there is no rev limiter, if there is it is over 7000 rpm
Old May 5, 2007 | 02:37 PM
PRAY HRD's Avatar
no limiter and best suited for a stock to mild setup.
Old May 6, 2007 | 12:47 PM
87ssMonte's Avatar
You can now buy a couple different manifolds for the LS motors.. GM has at least one, Edlebrock makes 2. MSd makes several ignition units for the LS motors.
There's alot of choices.
Old May 6, 2007 | 01:22 PM
jay_lt4's Avatar
yes there is a lot of choices now,, when i put my s-10 together the only choice was the edelbrock kit, and wow did the prices go up, when i purchased my edelbrock intake/msd ign box kit it was only $490, now they want over $700
Old May 8, 2007 | 04:30 AM
chris-m's Avatar
i've already ordered the kit you see, #7118 from edelbrock,but was unable to find out if rev limited.
its a fairly stock ls1 with a mild cam so hopefully will suffice for my needs, as its going in a lightweight car. i need to sort a rev limiter then by the look of it!
thanks for replies
rgds
Old May 8, 2007 | 12:17 PM
Darracq's Avatar
I think there is a built in rev limit. You can go to msdignition and ask the ? on the tech form.
Old May 8, 2007 | 04:14 PM
LQ4Monte's Avatar
I have the MSD 6010 unit and it has two programmable rev limiters than can be operated by a switch, hi/lo. At least that is what I gathered from the instructions.
Unfortunately, I haven't actually messed with it yet since I am in engine jail with my builder. Two more engines to go and it's my 408's turn.
Old May 10, 2007 | 06:38 AM
chris-m's Avatar
do you have a link please? i did email MSD tech direct but no replies to 2 emails.
thanx
Old May 10, 2007 | 06:39 AM
chris-m's Avatar
i'll look at the kit when it arrives then and see which model msd it comes with.
thanks
Old May 10, 2007 | 09:54 AM
Darracq's Avatar
thanx
www.msdignition.com
go to support and then to tech forms.
Old May 11, 2007 | 04:29 AM
chris-m's Avatar
thanks again, will look in there now.
