motorplate AND kmember? LSX fox.
Old May 5, 2007 | 07:10 PM
brady346's Avatar
Default motorplate AND kmember? LSX fox.
Ok guys, have a few questions. Can I use a motor plate AND a tubular K member? Where can I get a motorplate made and what do they cost? Also, will there be any clearance issues in the trans. tunnel with a 396 (3.905 X 4.125) LSX and TH350 setup? Finally, can I just use the factory rack and pinion? Thanks so much for any help you guys can offer. I have read what Ive found with the search button until my eyes are bleeding.
*edit*
I just want a lightweight front end (reason for tubular K) with as much header clearance as possible. I assume a K member is mostly for front suspension support???
Old May 5, 2007 | 09:43 PM
tirefryin_s10's Avatar
buy a tubular k member designed for a motor plate they make them with no motor mounts and then run a motorplate and modify the stock trans crossmember and youll be ready to rock
Old May 6, 2007 | 12:25 AM
brady346's Avatar
Thanks man. Thats the kind of answer I was looking for. Now, I need to know where I can pick up a motor plate and what is it gonna cost me?
Old May 7, 2007 | 01:33 PM
89lx-ls1's Avatar
i have some templates that i used to get my plate made. depending where you position your motor but slight mods could be made to them. i could send them to you let you check them out and then modify them and send them back and i could make you up a set. or you could call stenod and get one for about the same price. either way you will spend alittle over 200
