looking to swap
Picking the engine up and dropping it off, (9 Hour drive one way)
Ripping the 305 out
I also modified the original fuel sender by strapping a Walbro 255lph pump on and adding a return line.
See my swap page for more details. Also look at the El Camino Central LT1 / LS1 forum.
Can someone point me to a wire I need? It needs to go from the DCL to my laptop so I can monitor it with HP tuners. THanks
You need 3 wires, a constant battery power wire, Ground(this splits into 2 and goes to 2 pins on the OBDII connector) and the serial data wire from the PCM.
It is at connector 230 pin K.
I'm just gonna put some injector cleaner in the first few gallons and fire it up when the time comes. Any better idea's?
Here is my dash and my fuel pressure gauge mounted.
Here are some intake and radiator shots.
The silver piece in the top radiator hose is our block for the steam pipe and temp gauge, here is a shot from under the car looking at the bottom where the steam pipe is connected.
An overall shot.
They are LS1 fans from a 2000 camaro.
We got oil at the filter and oil at the pressure sensor, all good.
We dont really know how much pressure we have because we are using the LS1 sensor with the 1980 factory gauge, but it does show pressure so we are assuming its all good. No wierd noises while cranking it. Tommarrow we will finish up the OBD-II wiring and test the fuel pump, flush the fuel lines. Then we should be good to go, should be firing it up for real tommarrow or saturday.
Cant wait!!!!!
Again no leaks, not even an exhaust leak. the fans kicked on. and best of all the radio still works. lol
we do have one problem. The fuel pump wants to stay on all the time. Our pump is running through a relay, the relay is hooked to constant power and we think it is wired right but we have yet to check all the wires out.
What we surmise is that computer is constantly grounding the relay kicking it on. We worked on the assumption that the fuel signal from the computer was going to ground it. Can someone confirm this? I am going to call my wiring company tomarrow.
Again THANK you all so much.
