V6 to Ls1
Old May 20, 2007 | 05:36 PM
notredan54's Avatar
Default V6 to Ls1
My father has a 3.8L T5 1998 firebird and has purchased a 1998 camaro for the Ls1 and T6. I have many questions for what needs to be done to change the V6 to the V8 and was hoping some of you guys could let me know.
Old May 20, 2007 | 07:52 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Moving to Conversions & Hybrids Forum...
Old May 28, 2007 | 09:17 PM
notredan54's Avatar
Will the wiring harness from the 1998 camaro work in the 1998 Firbird for the LS1 swap
Old May 28, 2007 | 09:27 PM
G-Body's Avatar
sawzall wielding director
I don`t think the harness will be a direct plug in, but with some re-wiring it will work.
Old May 28, 2007 | 09:31 PM
bene's Avatar
Trunion King
You need to swap all the necessary things from your LS1 donor car to your V6 body ie: harness, K member, gauges, ECM, etc.
Old May 29, 2007 | 11:14 AM
95GreenZ28's Avatar
Should be a pretty easy swap for ya.
Old May 31, 2007 | 05:51 AM
Splitz's Avatar
be easier to BUY the a Z28/SS!
Old Jun 6, 2007 | 08:01 PM
notredan54's Avatar
So if I cut the harness and rewire it will work. Do i need to change gauges.
Old Jun 7, 2007 | 12:14 AM
G-Body's Avatar
The factory gauges will work, however you will need to use the tachometer calibration changed when you have the PCM retuned, and you will have to use the oil pressure sender from the V6 motor.
Old Jun 7, 2007 | 08:13 PM
notredan54's Avatar
Will the PCM need reprogramed for engine controls
Old Jun 7, 2007 | 08:54 PM
SSPerformance's Avatar
wrong its a directs plug and play
Old Jun 7, 2007 | 08:55 PM
wrong again u need to change the gauge cluster to a v8 cluster same years ad the hanress u will use
Old Jun 7, 2007 | 10:47 PM
97 camaro convert's Avatar
Default v6 supercharged to ls1
I am in the process of doing a 97 v6 supercharged camaro to 98 firebird ls1 engine exchange only on my fourth week keep me posted maybe we can help each other with the conversions dan.o
Old Jun 7, 2007 | 10:57 PM
the_merv's Avatar
Veteran: Air Force
The 1998 stuff will be pretty much interchangeable with itself. Some of the Wiring may be different.
The easiest way to do the Engine swap is to unbolt the K-member and unbolt the upper Strut Towers, and swap them directly out. That way you have the K-member, the Steering, and you won't have to **** with lifting an Engine, and swapping the Steering Racks, which is also required.
Old Jun 7, 2007 | 11:33 PM
G-Body's Avatar
Direct plug and play? How many of the wiring harnesses do you have to change for that to happen?
If you change the underhood wiring harness to an LS1 harness you will have to change the dash harness to the LS1 harness. Will the rest of the V6 harnesses from the car plug into the LS1 underhood and dash harness?? I know that if you change enough of the harnesses in the car it will eventually become plug and play but how many does it take. I have not done a 4th gen camaro LS1 swap, but from everything I have read it does not appear to be a direct plug and play swap. If you have done it I would appreciate a list of which harnesses you have to change to make it a plug and play swap, although I do not have any intentions of converting a 4th gen it would be a helpful list for many members on this board.
Old Jun 7, 2007 | 11:37 PM
G-Body's Avatar
Are you saying that the V6 cluster cannot be made to work with an LS1? The V6 cluster can be made to work with an LS1, speartech offers a plug and play harness specifically so that you can swap an LS1 into a V6 4th gen and use your existing dashboard wiring and gauges.
Old Jun 8, 2007 | 08:26 AM
G-Body's Avatar
1984camaroz28, You are right, after digging through your other posts I found a link in one of them that outlines the swap. Since notredan54 is swapping from a 98 v6 to a 98 LS1 the wiring is a direct plug in as long as he also changes the gauge cluster. As long as a camaro dash cluster will fit into a firebird dash he is good to go. Heres a link to the site in case anyone else comes looking for it. http://www.tacreationsusa.com/3_4_3_8_v6_to_ls1.htm
Old Jun 8, 2007 | 08:04 PM
notredan54's Avatar
Thanks alot everyone you are a big help.
Old Jun 9, 2007 | 12:44 AM
what do u not understand about being wrong... ive done the swap a few times a 98 car will be a direct plug and play with a 98 LS1 harness i only have one sitting ibn my garage.....u have to tape on hot wire outa the fuse boc to the pass side coil for power.....
Old Jun 9, 2007 | 12:45 AM
thank you..... yes the cluster will fit...... any question shoot me a pm
