1st Post-Bought LS1 Today
Here is my list so far:
ECU
Harness (how much harness shold I take?)
Dual Fans
Drive Shaft
Trans. Crossmember
Shifter
That's all I can think of. What else should I grab?????
TIA......Glenn P
The Pedal that comes with those ads/motors are usually Drive By Wire setup, the F-Body didn't come with that setup. Trucks, Vettes, GTO, etc came with the DBW T/B's. or they are just throwing in the F-Body pedal assembly.
Calif changed the law.. they eliminated the rolling 30 year law.. only 75 and older are now exempt and that is it! That Sucks.. I was waiting for a few of my cars to go exempt.
Now the fun starts. I look forward to working on this project and getting support from you guys.
Not sure if I have an LS6 block yet. Found a # on the block near the drivers side head 12559(3?)78. The VIN on the donor Camaro is 2G1FP22G822148869. Anybody know how to crack the code?
Two follow ups:
67rsss-You mentioned a trans. modual-I could not find anything that looks like it was wired to control the transmission. Could you give me more info???
BCzee-Fuel tank sensor/sender-I was not abel to get the this. Was it located in the fuel tank? More info on this please....TIA..Glenn P...Glenn P
Can get something to work out of another Camaro or something that will work.
So, where is Fallbrook... I am in the SF Bay area..
Fallbrook in in San Diego (North County). I lived in Vallejo as a kid so I know your area pretty good.
http://i187.photobucket.com/albums/x...Picture001.jpg
1) Is the sensor in the top of the tank above the fuel or is it in the fuel line somewhere?
2) Is there an electric valve in the vent line that is opened and closed when the PCM detects excessive pressure?
3) Where does the evap line tie back into the LS1 for the suck action?
Out of all the smog stuff I need to worry about, this one is probably my biggest problem. Mostly due to my old fuel tank. If I need to mount a sensor in the top of the tank, I may make a whole new tank out of aluminum. At that time, I could put my fuel supply line in the bottom.
TIA..GP
