Welding oil pan on the block
Old May 25, 2007 | 07:14 PM
Midnight68's Avatar
Default Welding oil pan on the block
Is it safe to weld my oil pan while it is still bolted to my block? Its an LS2 and I planned on leaving it bolted to try to keep it from distorting. I have the harness removed is there any other precautions I should take? Should I remove the oil pan gasket and bolt it to the block would that also help to keep it flat?
Old May 25, 2007 | 07:17 PM
BLWN1's Avatar
If not can you bolt it to wood or something.....
I first read this and thought you wanted to physically weld it to the block... man its been a long day
Old May 25, 2007 | 07:57 PM
cvman's Avatar
If you had no other flat surface you can do this. You do have to take off the gasket, though. The heat generated from the welding will disipate fast enough as to not hurt the block. Make sure the pan is completely clean, aluminum is very hard to weld when it's dirty.
Old May 26, 2007 | 06:46 PM
Midnight68's Avatar
Well the plan is to run it through the dishwasher one day when the wife is gone to clean it. I just wanted to use the block as it is easy doesn't require making a jig to bolt it too.
Old May 26, 2007 | 06:59 PM
Thaniel's Avatar
Any chance weld splatter would get up into the engine?
Old May 26, 2007 | 07:23 PM
cvman's Avatar
No such thing as weld splatter when you heliarc aluminum. Don't you have a pressure washer, Midnight?
Old May 26, 2007 | 09:27 PM
Midnight68's Avatar
No pressure washer, but I could go to the car wash. Why?
Old May 26, 2007 | 09:32 PM
the_merv's Avatar
Veteran: Air Force
That's great..
What exactly are you welding on the Pan?
Old May 28, 2007 | 11:11 AM
Midnight68's Avatar
Have to weld the pan to clear the drag link. Its an LS2 going into a 68 Camaro
