Fuel Pump Question
Old Apr 30, 2003 | 08:59 PM
DaleMX's Avatar
Default Fuel Pump Question
Speed Inc. told me I needed a sump to run an external pump.
My tank is not setup to accomidate an internal pump. Does
anyone out there know of an external pump I can use that
doesn't need a sump? Is it just a question of priming it?
Old May 1, 2003 | 06:48 AM
67ls1CamaroProject's Avatar
Default Re: Fuel Pump Question
I am using an inline pump, high volume/pressure walbro type. I am violating all recommendations. No sump, pump mounted higher than the tank, etc. Once the pump is primed, it is no longer an issue. My car runs excellent. I do not race around tracks to worry about fuel slosh/starvation. I do drag race, but have not yet with this motor. We shall see. Worst comes to worst, I will make sure I have a half of tank of gas.
Old May 1, 2003 | 07:12 PM
DaleMX's Avatar
Great, I was going to try it but wondered if I would fail. Besides hacking up my tank at this point would be a real hassle. I was looking at the 255 LPH external and adjustable regulator from Speed Inc. I'll try it, if it fails then I'll drop the tank. Thanks for the reply.
Dale
Old May 1, 2003 | 07:39 PM
Rod G's Avatar
From everthing I read before I done my 406 efi 67 nova, an inline pump is very efficent at pushing but not at pulling, that is why a pump mounted lower than the tank and being gravity feed the pumps worked well and would last the normal life span. When a pump has to pull for fuel everytime you turn the switch on this shortens the life of the pump to (what I have read on this subject even if only for an instance) normally less than a year. I can't say for sure from experience but I cut a new tank apart, put a baffle and in-tank pump in. This was 2 years and 9000 miles ago with no problems. My latest project a 79 elcamino, LS1,4L60E trans. was done the same way, engine started immediately but have about a month,s worth of restoring left,but am really anxious to try it out.
Old May 2, 2003 | 06:46 AM
Well, before the LS1 install, I ran a Holley Pro Jection system on my big block with its external inline pump mounted in the same spot above my tank. That system ran for the last 4 years without failure. That pump only put out 15 psi, but pressure shouldn't matter.
