5.3 harness
Old Jun 1, 2007 | 07:39 AM
1987earthquake's Avatar
Default 5.3 harness
If I use the 5.3 harness from a truck in my 87 camaro, what all can I delete from the harness/pcm? I guess what I need to know is what all goes along with emissions, i don't want any emissions. I know I can delete the secondary fuel stuff, clutch and what not, 4wd stuff. I just need to know what all goes along with emissions. I don't want to get too cut happy and cut wires I'll need.. Thanks
Old Jun 1, 2007 | 09:44 AM
bczee's Avatar
You should call John at Speartech or Jesse at Wait4meperformance to get a run down of what you can delete. Also the FAQ/Sticky are good information.
What I did was just connect my harness up to all of the sensors and accessories that I needed/wanted, then just start stripping out wire and connectors that you don't need. (usually the EGR, Air Pump, A/C, EVAL, etc), that is what I did and then told Jesse to flash my PCM with all of the deletes and add a basic tune.
You might want to get a pin out of the harness and PCM of the year that your PCM/Harness along with a wiring printout.
Old Jun 1, 2007 | 12:42 PM
Got all the wiring diagrams and some pinouts. I do want to keep A/C. I just want to delete all the other stuff I don't need.
Thanks for the info
Old Jun 2, 2007 | 12:14 AM
eagleuh1's Avatar
What year truck 5.3 harness. You can delete the evac solenoid, vent solenoid, rear o2 sensors. If its new enough, it won't have egr.
Old Jun 2, 2007 | 02:46 PM
It's from a 1999 z71
Old Jun 4, 2007 | 12:44 PM
Do I need the ebcm, bcm, manifold absolute pressure, ABS,
Old Jun 4, 2007 | 09:41 PM
G-Body's Avatar
sawzall wielding director
You do need the manifold absolute pressure sensor.
The EBCM, BCM, and ABS can be deleted.
