New guy question
Old Jul 3, 2007 | 09:46 AM
67rsss's Avatar
While that really is a good price, I think you will spend more than you think buying everything it doesn't have. Harness, PCM, Sensors, it all adds up fast. Dollar wise, you would be way ahead buying a complete pull-out with everything. You may find a good deal on a unit with a trans as well. Then you can sell off the trans to help offset some of your costs. I still don't know much about mating an older trans to the LS/LQ/LM series, but people on the site have done it. I don't know how much room you will have in the tunnel for a T56, but if you can get an LS1 with a T56, you will definately enjoy the double overdrive. We just got 26.6mpg on a trip to a car show. For dollar reference, we got our 2002 LS1/T56 for $3900 off ebay. This included reprogramming the PCM. Get the driveshaft from the donor so you don't have to buy a new yoke! Good luck on your vette!
Old Jul 3, 2007 | 12:43 PM
Schitzo's Avatar
mffi115
what is your budget for engine and trans. The LS1/T56 package has become very affordable. For $3500 you can get a low mileage Engine and trans to your door. Be very careful of incomplete engine and trans deals. They might sound attractive but buying those missing parts will add up. eg. buying an engine without accessories can prove costly ang trying to get all the bolts needed will get annoying.
Go to www.car-part.com and search for an engine and trans. Call around and haggle.make sure you get a deal as complete as possible.
all the best
Old Jul 3, 2007 | 01:42 PM
mffi115's Avatar
Default Thanks
Good advice on the engine. I'm in no hurry at this time. I have to move all my toys from AZ to CT by the end of summer. So I won't start work until later this year. According to a thread on the corvette forum, the T-56 will fit in the '73 vette w/ no mod to shifter location and only moving the cross member. JEGS makes a motor mount adapter for the conversion.
Old Jul 3, 2007 | 02:52 PM
67rsss's Avatar
You sure about that? I thought that in the vette applications you had to move the shifter up to the inspection panel? You may want to look into that one a little more to be sure. The stock shifter location on the T56 is pretty far back from the motor. For a 67 Camaro, it is about 4.5 inches back from stock. I do recall seeing a shifter (Mcleod???) meant for adapting the T56 to a vette. It attached towards the side of the forward cover, and required some modifications to the shift rail. I could be thinking of much older vettes however...
Old Jul 3, 2007 | 04:15 PM
mffi115's Avatar
Default Info from Corvette Forum
This is the answer I got to my post on corvette forum.
Quote:
Originally Posted by mffi115
What mods, interior and cross-member, to install the T-56?
Interior: None. (The shifter does need to be modified to move the stick left and rearward to fit through the hole in the console.) Link to pic.http://picasaweb.google.com/matt.bro...82961709068146
Body: Trim the hole in the tunnel for the shifter to come through. (This pic is before the shifter was modified.)
Interior
pic
Crossmember: With the right bracket... none. other pix
Attached Thumbnails New guy question-t56_tranny_mount.jpg   New guy question-t56_hurst.jpg   New guy question-t56_tranny_bracket.jpg
Old Jul 4, 2007 | 06:30 PM
67rsss's Avatar
What vehicle was the T56 in the center picture out of?
Old Jul 5, 2007 | 09:07 PM
mffi115's Avatar
I think an '02 Camaro. I'll ask.
Old Jul 5, 2007 | 09:08 PM
mffi115's Avatar
An '02 Camaro, I think. I'll ask when the CF website is back up.
Old Jul 8, 2007 | 09:36 PM
mffi115's Avatar
Default Answer from Corvette Forum poster
Scooter70,
What donor car did the T-56 come out of?
It's an F-body T56 that I bought brand new at D&D Performance. They're only 15 minutes from my house. The shifter is an F-body Pro 5.0 that's been cut down and then I welded a couple of pieces of 3/8 steel to move the stick location.
Old Jul 8, 2007 | 10:23 PM
sssuch's Avatar
Tach problem is easy just get a electric tach from a 75 -77 it will be a perfect match for your 73 just electric. As far as bolting your motor to the original 4 speed , do a search of previus posts by me and you will find all the info you need. Stan 70 Corvette LQ4 4 Speed.
Old Jul 14, 2007 | 11:14 PM
mffi115's Avatar
Thanks. I went to 20th Street Auto Parts (Porsche, Audi, and Vette salvage shop) in Phoenix the other day to see if I could get one. The guy knew exactly what I needed it for. Unfortunately, the only one they had was still in a complete '77 they were trying to sell. I get the tach and interior if they break it up.
Is there a module or something other than the complete tach that will work? I ask because the old guy who was the vette expert blurted out something like "You only need the..." before it looked like he caught himself and walked off. The bosses were standing there.
I got a good used hood from them.
Old Dec 11, 2010 | 04:47 PM
  #32
mffi115's Avatar
Default Update
Forgot I had posted this thread. Well, here's what I finally decided on and , boy, have I learned a lot since I first started this thread...aaand a hell of a lot more to learn!
My project blog: http://ls273stingray.blogspot.com
