Ls1 conversion- power estimate?
Old Jun 15, 2007 | 05:09 AM
chris-m's Avatar
Default Ls1 conversion- power estimate?
anyone like to hazard a guess what sort of power (flywheel) and torque the following set up might make using a carb conversion/msd setup?
stock 2000 Ls1 5.7L
edelbrock performer manifold and msd ignition pack
750cfm BG Demon carb
220/220 deg cam .56 lift
ATI crank pully damper
ARE dry sump conversion
4-1 tubular headers cermic coated
3" exhaust systems - no cats
pancake 14" air filter
no a/c or p/steering
rev limit circa 6500rpm approx.
Old Jun 15, 2007 | 05:57 AM
hpmotorsports's Avatar
guess 450-475hp
Old Jun 15, 2007 | 08:14 AM
hosspowerinc's Avatar
Ill agree with that. Why not go with a bigger cam for more power? Youll need port work to get much more but I still think you could make it to 500hp pretty easy.
Old Jun 15, 2007 | 10:58 AM
chris-m's Avatar
tbh I am suprised that it might make anywhere near that much? i thought the stock engine being circa 350bhp that the above should clear 400bhp reliably enough.
i've only gone for a very mild cam to keep it all ultra reliable and driveable. its going in a lightweight track car so anything 400+bhp i would be pleased with anyway, plus there would be scope for future power gains then if it ever gets boring!
Old Jun 15, 2007 | 12:03 PM
9540x's Avatar
Carbs on LSX engines really open them up. You can get a ton of cheap HP by going carb. 475 seems a little high, but you'll definitely be making more than 400+. Myself, i'd trust the lower estimate of 450.
Old Jun 15, 2007 | 04:34 PM
sparkwirez06's Avatar
i believe the stock ls1 is 417 fhp, chp did a test with cam swaps, don't remember the date, ls engines are rated rwhp.
Old Jun 15, 2007 | 04:46 PM
my 5.3 with a 750 carb,pulled 350rwhp with a224 cam
Old Jun 15, 2007 | 06:04 PM
Darracq's Avatar
I would say 425-450
Old Jun 15, 2007 | 06:07 PM
Darracq's Avatar
I dont know about that, i cant get mine to run with the stock internals camaros. I am sure i have some tuning left, but i am a 1/2 second off and lighter.
