Do I even need to install cat/converters?
I have the stock computer (from 2002 Camaro) in here, so is there some special "flashing/cleaning of the memory" that will need to be done if I build an exhaust system that doesn't run cats? Is this something I can do myself with software and a laptop with the proper ECM plug?
One more question, as I think this through: Do I need to add in another o2 sensor in the back of the exhaust system somewhere fin order for the ECM to function correctly?
Lotta theory questions here... thanks for your patience.
Paul
You can eliminate things you don't need like EGR, rear cats, VATS, etc easily w/ HP tuner or similar product. Tuning the PCM is best done on a dyno.
