O2's and Fouled Plugs?
Old May 7, 2003 | 06:58 AM
67ls1CamaroProject's Avatar
Default O2's and Fouled Plugs?
I guess I am having the same problem as Jeromio. My car has run fine open exhaust for the past week(no driven). I finished up the exhaust and installed the O2 sensors and the engine ran like **** when warm. Since then I have been only able to get it to fire on maybe 1 or 2 cylinders before dying. I pulled the plugs last night and they are black. I will be replacing them tonight. What is to keep them from fouling again. I have no diagnostic tools yet. This will be the first time starting the car with the exhaust and coolant systems in complete working order so maybe if I perform the PCM idle learn procedure completely everything will be okay. What do you guys do for the idle learn procedure?
Old May 7, 2003 | 09:48 PM
63 Split Window LS1's Avatar
Default Re: O2's and Fouled Plugs?
I had the same problem. A friend of mine who runs the repair shop for a large Chev dealer brought his testing equipment by the house and we discovered that I had misswired two of the O2 wires. My son-in-law built my wiring harness and those were the only two mistakes so I was happy.
Old May 8, 2003 | 06:51 AM
It is officially time for me to take a break from this project. Yeah my plugs were carboned up, so I put new .99 cent plugs in to see what is happening. Still didn't start. Noticed the inline pump sounded louder. Checked the fuel rail...AIR!!!! No gas in the tank. Put gas in fired right up. You would be suprised how much easier it is to start an engine with gas.
Old May 8, 2003 | 09:56 AM
jeromio's Avatar
Yes, I have the exact same problem. Haven't had time to do much with it since Sunday. I put $2 plugs in mine . I guarantee they'll get fouled again until the close loop issue is sorted. I am hoping in my case that I have an exhaust leak and fixing that will take care of the problem.
I'll also be swapping out the O2s for the other set I have. I don't suspect wiring since I am using a stock FBody harness - the only mods were to cut off the trans stuff (A4 harness, T56 car).
BTW, I also ran mine out of gas. Was able to figure it out pretty quickly though, so, not toooo embarrassing. My stupid brand new Autometer gauge reads 1/2 full on an empty tank?!? FBody sending unit should work perfectly, so I think I musta got a bad gauge.
Old May 14, 2003 | 08:37 AM
jeromio's Avatar
Have you solved this problem yet? I've been driving the car with O2s unplugged. I swapped out the pass. side sensor and I fixed an exhaust leak, but it still ran like crap in closed loop. I still have yet to inspect the driver's side O2 sensor.
Basically, I'm still in the dark and I'm looking for someone else to solve my problem for me
Old May 14, 2003 | 11:30 AM
I do not think I have a problem. I have not checked my plugs since I replaced them, but I did run the car up to 235 degrees to test the fan circuit and it ran fine. I have not logged any road time yet, but I hope to this weekend. I will let you know if things should get worse. Make sure that you perform the Idle Learn Procedure before stabbing the throttle. When I didn't do this my car ran like ****.
Old May 14, 2003 | 04:50 PM
C4VetteLS1's Avatar
how do you perform the idle learn procedure on a car that has no a/c etc??
Old May 15, 2003 | 06:34 AM
Manual says to get the water temp to 176 degrees and then let it idle for 5 minutes and then turn it off for 30 seconds. So, if it is cold it is going to have to sit and idle a long time to reach 176 and then 5 more minutes...all without touching the throttle. Doesn't say anything about ac.
