67 camaro speedometer ?
You can get a 12mm adapter to what size your gauge sender uses (1/4, 3/8 or 1/2").
I and many have just broken off the top part of the LSx sender and tap it to what NPT size of the new sender.
So if I am understanding you correctly you broke the top part of the sender at the back of the block and tapped it? I guess what I am wondering is how my 2000 got the oil pressure signal to the gauge and wanted to try and do that with the aftermarket gauge.
Do you think that you could just use the sensor adaptor from Street and Performance and they put the sensor in that instead of the adapter Stewart Warner sends. I would think that would work but I not sure wanted to get your opinion
or are you trying to use the 2000 gauge set ?
I use both the idiot light on the dash (using the sender on the back of the block) and also have a pressure gauge on the adapter on top of the filter.
So tell me I have been trying to get an answer on this. On the SW maximum performance gauges does the needle light up too. I know that they are glo through gauges but I saw some pictures one time and cant find them anymore but it looked like the needle did not light up. And if you have these gauges would you mind posting some pictures of day and night time pictures. Thanks for your help so far mike
No I am using an aftermarket gauge. I have the covan dash and am using stewart warner gauges. So the sensor at the back of the block is just for the light warning you that you have low oil pressure?
So being that I have after market gauges I wont be able to use the idiot light I am guessing. So the best way for me to actually get my oil pressure gauge to show what oil pressure I have is to drill and tap the adapter at the top of the filter?
I tell you what I have done all the work to my engine and know all about the LS1 engine but I found out that I hate wiring and know nothing about it lol. Wish I lived closer so you could help me out on this thing lol. So are you saying that you did put it in the side of the head and dont like that it is not accurate so therefore are going to move it at a later date?
Well I didnt figure it being close to the header was that big of an issue considering that the coolant temp sensor for the PCM is right next to the driver side header so i figured it would be the same. And you are right I really dont think i will be having to worry about the temperature of the engine because the thing doesnt get that hot anyway. And if it starts to overheat since i will know what the normal should be if it went over then i would know that i was having a problem
Oh I will be using an aftermarket stewart warner sender and I am going with the stainless works LT's
