school me on wiring for efi
i think i shy away from the idea of efi because i dont understand how the wiring goes. ive been looking at the the picture of the ls1 6 speed harness on the speartech web page and it doesnt look that bad.
so how do you wire the pcm? i assume all the plugs go to their desired location on the engine (crank, cam, coils...) but what about the rest? is there a mass of wires that you must splice to your cars fuse block?
i hear about people building relays and all sorts of madness. is it possible to just ground the pcm, supply ignition voltage, hook up the tach signal? when using a stand alone harness. much like an msd box.
my 69 camaro has an 18 circuit painless harness. it has wires for everything! even an electric fuel pump. wiring was super easy. just wondering how easy that would be to adapt.
found a complete 2000 z28 ls1 set up for $2500. includes everything, front accessories, wiring, complete intake to pan, with pcm.
Yes there are more wires than 4-6, but it is mostly
plug and play as the sensors were on the motor.
All wires were marked well.
Fuel Pump you would want to use the Harness
fuel pump feed. My harness had Fan relay and fuel
pump relay connectors built in and just plugged in
the relays. Customer service was fantastic!!!!!
Always a quick on the phone answer.
The only interlinking of harnesses I have is supplying
the PCM harness with constant 12V and ignition 12V.
Other than that my harness has a seperate fuse
block and attachment to the Alt Batt post.
My Speartech harness just needed 4 wires to run, then also had tach, speedo, fan control, cruise control (I have electric throttle) and AC idle control additional. It was not hard to wire into my existing system and fired up on the first revolution of the engine. It came well labled with excellent instructions.
Good luck with your project, DO IT!
Pat
https://ls1tech.com/forums/conversions-swaps/684612-story-our-ls1-swap-into-67-camaro.html
looks like you had a hell of a lot of wires goin on there for a stand alone harness.
here is the build thread for my camaro. no ls1 but still pretty decent.
http://www.camaros.net/forums/showthread.php?t=90303
