Some ?? on LS swap into Foxbody
Old Jul 26, 2007 | 07:42 PM
PRAY HRD's Avatar
i cheated and bought a completed swap for $9000! then i changed it alot performance wise from there.
Old Jul 27, 2007 | 12:22 AM
SSrussman's Avatar
Finally a post from someone who accomplised the swap....nice notch you got there...
Old Jul 27, 2007 | 08:50 AM
PRAY HRD's Avatar
thanks, but you meen someone with a completed swap. as i said, i bought mine this way, then worked on it from there.
Old Jul 27, 2007 | 02:17 PM
SSrussman's Avatar
damn i can't believe you got that for 9k that's a steal IMO....well keep it going and I'm hoping to join the club in a few months lol...
Old Jul 27, 2007 | 03:38 PM
Mr. Hyde's Avatar
Mine runs and drives like a champ, save the slipping SPEC clutch that's in there now.
-2001 LS1/T56 w/ harness, ECU $4200
-AJE K-member $420
-Thunderbird Turbo Coupe pedals $80
-T56 shifter $20
-T56 yoke $70
-98+ F-body radiator/fans $160
-98+ F-body T/O Bearing $125
-Wilwood clutch master, McLeod line and addt’l line $220
-96 SN95 transmission x-member & mounts $75
-Paxton 1000 hp EFI pump $125
-Aeromotive AFPR w/ fittings and gauge $225
-fuel return line/fittings, braided line, fuel rail adapter $315
-fuel filter & fitting $100
-Intakehoses.com setup $75
-intake filter $40
-86-93 EFI throttle cable $28
-Taylor plug wires $60
-Pacesetter Race LT headers $295
-(header fabrication) $775
-(exhaust fabrication) $400
-(mufflers/pipe/reducers) $217
- hoses, belt-522K6, oil filter, plugs, pcv $100
-PCMAmerica basic tune $62
-PCMAmerica harness $324
-offset rack bushing kit $10
-continuous duty solenoid $25
-coolant recovery tank $20
-metric adapter fittings $15
-air temp sensor $15
-O2 Sensors (2) Bosch 13111 $150
-Autometer Water Temp gauge/sender $75
-replacement water temp sensor $20
-Autometer speedo & tach $340
-LS7 clutch kit $450
Total spent so far: $9631...
Of course, this is doing everything exactly the way I wanted it and paying some hefty labor charges. Of course, these were the items I didn't have time or ability to tackle myself, to my satisfaction. Also keep in mind that while I did look hard for good deals, I primarily wanted to use as many new parts as I could. This **** ain't cheap
Old Jul 27, 2007 | 08:20 PM
PRAY HRD's Avatar
damn right it's not! lol. i think buying a completed one turned out to be the best bet.
as far as a clutch, if i may, i would like to suggest getting a Textralia OZ700 if it's in the budget, like $1000 shipped new last i saw. you would not believe how nice of a clutch this thing is! it's great on the street and grabs like a MF'R when you want it too. you can also slip it a little when needed and not worry about it, it's rebuildable, and i hear if there's any chatter at all, it's minimal and has a brief breakin period.
i got VERY lucky and pounced on 1 up f.s. on here with a billet steel flywheel for only $500 shipped! it was advertised as having only 1300 street miles and some play time on it, but no passes yet. when i got it, it was perfect! couldn't be happier with it.
Old Aug 2, 2007 | 07:18 AM
SSJIMMY's Avatar
Hey Russ that Blue one we saw at teh track one night Paul and Chris built that for that guy so i know They could help with getting parts and the swap itself. Cant wait to see yours done though.
