steering box CLEARS headers!!!!!! pics
Old Aug 21, 2007 | 11:31 PM
CarlC's Avatar
Leon,
Can the headers be installed after the box using an undercar installation?
Old Aug 31, 2007 | 05:59 PM
leonpiper69's Avatar
sorry carl i havent been in my garage in 3 weeks almost, its been about a hundred and humid everyday and a few days with the heat index it hit 112!!!!!! i looked at the headers and as far as installing them from the bottom, i dont think they will fit. i did mine with the box out and slid the box up from the bottm. i forgot to check the dist. from the firewall i'll check tomorow though. any other pictures or anything i can check for ya?
Old Sep 3, 2007 | 11:53 PM
Rybar's Avatar
Originally Posted by CarlC
Leon,
Carl, just saw this thread. Yes you can install the header from under the car with the steering box installed. My steering box looks very similar to yours. I removed the factory bolts that hold that plate down and installed button head allen bolts. (the two that come close to the header) I also ground down the cover so that it clears the header tube. I'm running S&P plates with poly engine mounts.
Old Sep 4, 2007 | 03:53 AM
LS1 Coupe's Avatar
On the bolts on the steering box, try using some button head allen bolts instead of grinding. I'm not sure if the steering box is anything different from a vega steering box but I have seen some smaller boxes out there.
Old Sep 4, 2007 | 08:11 PM
im getting button heads to try, but lowes does not have then so i have to order them in a 50 pack from granger, we'll see, they should help alot.
Old Sep 5, 2007 | 11:03 PM
CarlC's Avatar
Leon,
Thanks for the info. Did you get a chance to measure the distance from the firewall to the vertical surface of one of the heads?
Old Sep 5, 2007 | 11:07 PM
CarlC's Avatar
Rybar,
I think you may have a rack & pinion header. SW stated that their headers are designed around the S&P plates, so yours should have been easy. Yeah, like any header install and fitment is easy!
Old Sep 6, 2007 | 02:00 AM
Rybar's Avatar
Rybar,
Pretty sure mine are the stock steering ones. I got them from Jason (G-Force Design Concepts) the guy who built Fuel.
Old Sep 9, 2007 | 06:54 PM
carl i checked off the back off the head and its about 2 inches averywhere except one spot where the firewall sticks a out a smidge on the driver side and there its at 1 1/2 inches at its closest
Old Sep 9, 2007 | 10:35 PM
CarlC's Avatar
Thanks Leon. Which head did you measure? They are offset.
Old Sep 10, 2007 | 11:17 AM
Teetoe_Jones's Avatar
Here is a measurement from the pass side head to the firewall using ATS plates and mounts.
Here is the ATS Tri-Y header clearance on the P/S box:
Here is another view of driver side header in stainless steel:
Hope that helps some guys.
Tyler
Old Sep 10, 2007 | 12:24 PM
  #32
CarlC's Avatar
Hey Tyler. Thanks for the dim's.
Old Sep 10, 2007 | 02:39 PM
  #33
i measured the driver side, i'll check the pass too, i wasn't even thinkin bout how they are offset.
Old Sep 27, 2007 | 02:20 PM
  #34
DCx's Avatar
DCx
about the spark plug issue. Magnecor offers plug wires for cars with headers. they have a 45* boot. think that will help?
#85259 - Magnecor 8.5mm Spark Plug Wire Set (Recommended for vehicles w/ headers)
Application:
1998-2002 LS1 F-Body
1997-2006 Corvette
2004-2006 GTO
2004-2006 CTS-V - Black
2006-2007 Trailblazer SS
$86.99 (from thunder racing)
Old Sep 29, 2007 | 12:09 PM
  #35
john 67's Avatar
Leon Did You Order The Bolts Yet .i Have A Place Near Me Where I Can Buy Four If Tou Need Them ,john
