clutch line adapter/fitting leakage
it leaks somewhere at the slave. now ive never dealt with an internal slave with quick disconnect before, are there any tricks or tips or anything? im not sure what piece its leaking from (pulling engine tomorrow) so just throw out some suggestions till i can crack it apart and try to find it
just for my own stupid brain to be at ease:
there should be no teflon tape on an AN fitting correct?
they are generally tightened to 40-50ish ft lbs on a -4 size?
theres no tricks or stupid procedures to install the mcleod adapter? just pound out the rollpin, put the adapter in, and pound the rollpin back in place? no alignment or any other gay ****?
thanks guys, this was my first real snag on the swap and thats mostly thanks to this site <3
its super tight in there. but id like to test it for leaks before it spews all over my clutch.
red package, white tube? hehe
yeah...thas wat it is...permatex....and the sealants are white too...now when i bought the remote bleeder from a sponsor here...he sent a lil sealant package...but it wasn't anything like i bought...it was really liquidy and purple/reddish...
i have this -4 to -3 adapter
and this mcleod adapter
does anyone see a problem?
the mcleod adapter isnt long enough/the summit adapter is too deep. it doesnt seal up against the female side of the -4 to -3 adapter.
i think i just might shorten the summit adapter and give it a shot. if it works, awesome, if it doesnt, looks like im selling a mcleod quick disconnect and waiting for the russel one haha
they didnt have a -4 to banjo line that fits with the wilwood master or i would have. and i didnt get a russell one because they have been on backorder for over a month. im on a tight time constraint to get this car done as my season is starting in a couple weeks.
regardless i cut off about 1/8th an inch from the summit adapter with our air cutoff wheel, cleaned the threads a bit and reinstalled everything. so far so good! holding pressure like a champ. i have a picture ill upload tomorrow.
datboibrad- the purpose of a an fitting isnt to seal the ends of the housings together, its to seal the 2 angled surfaces on the inside. i dont know if thats going to work. you need to have the 2 pieces inside butt against each other, not the ends of the pieces.
