How to get the AC working?
Old Aug 2, 2007 | 05:04 PM
jeepinpete's Avatar
Default How to get the AC working?
Since the search on LS1tech seems to be a bit broken (can't search just this section, only the entire site), could someone give me an idea what I need to do to use the stock 5.3l AC compressor with older AC system? What sensors/switches does the PCM need to operate the variable AC compressor, if any? Will I need to change the condenser to a larger unit, since this will be a R12 to R134a conversion? Does the orifice tube need to be changed for a different type? The stock AC system on my Jeep is thermostatically controlled and used a york compressor, and had a low pressure limit switch. I'd appreciate any info or experiences you guys have on this topic.
TIA,
Old Aug 2, 2007 | 06:28 PM
eagleuh1's Avatar
What year is your setup(5.3)? Are you using the pcm for the 5.3?
Old Aug 3, 2007 | 08:14 AM
jeepinpete's Avatar
It is a bone stock '99 5.3l. The only change to the PCM is the removal of VATS.
Old Aug 3, 2007 | 08:16 AM
ghettocruiser's Avatar
Not sure about a way for you to hook it up... but for the search check this out.
https://ls1tech.com/forums/user-support-resources/758705-temporary-search-enhancement-tips.html
More specifically, to search in a particular forum:
"To search within a specific forum:
1. Get the forum id number. (Hover over the forum, and look for the number in the status bar as above)
2. In the search box, type forumid:<number>.
3. As above, you then specify the stuff you want to find in the posts. ie. forumid:45 fuel injectors"
Might help you find some answers...
Justin
Old Aug 3, 2007 | 08:57 AM
jeepinpete's Avatar
Thank you for that information! I rarely go anywhere other than Conversion & Hybrid section, so I would have never seen that.
