5.3L is it worth it?
Old Dec 15, 2009 | 01:06 PM
  #41
Zman98's Avatar
Originally Posted by omc8
Yes this build has been done before,Played with this idea myself if my old LS-1 block turns out to be bad.First thing you have to decide is what crank your going to use ?I believe the 5.3 crank is balanced to the smaller bore size pistons.So if your going use stock LS-1 pistons you would be better off to use a LS-1 crank.I think someone makes a over sized piston for the 5.3 crank, this may be an option but I have not researched it .Maybe someone that has done this could tell us?
Why cant ya get it rebalanced? Something with a LSX that prevents that? If I had to get a crank might as well stroke it a bit. But stroking it without aftermarket rod and pistons would be pointless right? Im curious what the CR would be with the ls1 pistons a.d 5.3 heads milled 0.030. Around 11.5?
Old Dec 15, 2009 | 06:53 PM
  #42
EL T1's Avatar
Is there a core charge from LKQ? Anyone?
Old Dec 15, 2009 | 09:02 PM
  #43
white84z28's Avatar
yeah, 100 bucks but my sales person said they take damn near anything as a core, didnt even have to be the same motor, apparently they send em for scrap.
Old Dec 16, 2009 | 08:45 AM
  #44
omc8's Avatar
Yes you could balance your 5.3 crank thats a option, here in my area its 150 bucks to balance a LS crank, just had one done this past week.The cheapest way would be to go with the complete LS1 rotating assembly.So if you have the rods and pistons ,get that crank too.Which heads are you going to use the old #706 casting,if you use these you will difinitly get a bump in CR.
Old Dec 17, 2009 | 02:31 PM
  #45
omc8's Avatar
Originally Posted by white84z28
You might want to check out LKQ recyclers. I just picked up a 2002 5.3 LM7 with 112k miles for 450$ complete from intake to pan with accessory brackets and most of the harness, they cut off the lead that ran to the relay box. It even has the coils and exhaust manifolds. They will actually ship in a unit that you need for no cost if one of their other yards has it.
I opted to get my motor with just a startup warranty as i plan to cam it before it even gets into the car. This saved 100 bucks off the original 450 . I'm going to be running the Kwik Performance alt only bracket as i will be converting to manual steering but LKQ has the alternators and power steering setups as well and for a killer price. I picked up a 130 amp truck alternator for 25 bucks, which is killer considering people here want 50-100 for stock 105 amp f body alts.
Thats great that LQK knocked 100 bucks off ,and a good price on the alternator .But typically I buy from recyclers that don't have a core charge .There is only one yard that pay a core ,my local Pick n Pull and thats because there engines are only 169 dollars and there core is 30.IMO core charges are a ripoff ,the scrap value is only 30 to 40 bucks .But if LQK shipped that engine in from one of its yards from a long distance ,with no shipping charge to you,then I guess you cant complain about that core charge.
Old Dec 18, 2009 | 07:56 PM
  #46
omc8's Avatar
If there is a Pick n Pull in your area check them out there prices are hard to beat and they have over 30 some yards in the U.S alone.
Old Dec 19, 2009 | 01:24 AM
  #47
Zman98's Avatar
I haven't gotten anything yet. Its a future build I'm just getting some research done first. Here its 115 to get the rotating assembly balanced. Im new to the LSX crowd and not sure how good the factory balancing is in these engines. I know its a great deal of difference on a older small block. Basically what I wanna do is, get a 5.3 and make it into a 5.7. Truck motors are hella cheap and everywhere. The 65 lb difference doesn't bother me. But the raised CR and cheaper seems like the way to go. However I will send off the heads to get ported and polished. Any castings to avoid with a 5.3?
Old Dec 20, 2009 | 08:32 PM
  #48
omc8's Avatar
I haven't gotten anything yet. Its a future build I'm just getting some research done first. Here its 115 to get the rotating assembly balanced. I'm new to the LSX crowd and not sure how good the factory balancing is in these engines. I know its a great deal of difference on a older small block. Basically what I wanna do is, get a 5.3 and make it into a 5.7. Truck motors are hella cheap and everywhere. The 65 lb difference doesn't bother me. But the raised CR and cheaper seems like the way to go. However I will send off the heads to get ported and polished. Any castings to avoid with a 5.3?
No if your getting the heads ported ,it does not make a difference what casting you go with.Early 5.3 LM7 will have casting #706 or #862 these after a cnc ported program will flow with the best.These heads in stock form have a 1.89 intake valve.But if your just having a mild hand port and good vj you may want to consider going with later style castings #799 or some had the 243s which have 2.00 intakes.799 and 243s are pretty much the same just a different casting process.And the early ones can be machined to take up to 2.02 intake and 1.57 exhaust.All stock 5.3 heads are 1.55 on the exhaust side.
Old Dec 22, 2009 | 03:58 PM
  #49
omc8's Avatar
If you find #243 castings on a 5.3 ,these are the LS6 heads less the hollow stem intake and sodium filled exhaust valves.These would be a good ones to get your hands on!
Old Dec 23, 2009 | 02:05 AM
  #50
Zman98's Avatar
Thanks for the input. That helped me out quite a bit. I have heard the stock 5.3 heads flow nice and ported work real well. And there are 243 heads on a 5.3 from factory???
Old Dec 24, 2009 | 03:40 AM
  #51
john59's Avatar
Yes they do I have an 07 Impala SS with a 5.3 and 243 heads on it at the shop I believe they have 303hp its hit pretty good in the front and I'm thinkin about taking it out and putting it in my S10 Blazer 89 with a small cam 224/228 or so( Love that cam in my Vette) LS6 Intake and headers probably make close to 400 hp or maybe more.
I believe it was Super Chevy that did a 5.3 build edelbrock heads 220/224 cam and boltons it made 441 hp, and with 243's on it already I don't think I'll be that far off there mark for a lot less money, especially in these lovely times.
found the link
http://www.superchevy.com/technical/...53l_parts.html
Old Dec 24, 2009 | 04:08 AM
  #52
Zman98's Avatar
But won't the different bellhousing pose a problem in swapping that LS4 in a rwd? I was gonna do an LS4 swap in my grand prix but steered away due to the "wrong wheel drive" lol.
Old Dec 24, 2009 | 04:14 AM
  #53
robstah's Avatar
I was able to pick up an aluminum 5.3L LM4 with 60k miles out of a 2004 Rainier for right at 500 dollars. The deals are definitely out there if you know where to find them.
Old Dec 24, 2009 | 04:16 AM
  #54
john59's Avatar
Lol, Just taking the motor, prob use a 4L60 or 4L65 behind it, It already has 3.73 posi 8.8 explorer rear in it so I'm good there, but I will have to mock up a driveshaft. theres a 350 tbi motor and 700R4 in it now edelbrock manifold and headers basically stock and it runs damn good, truck is light. So rather than deal with old school block and prob Vortec heads and such to make more power I'd rather go with new technology, that 5.3 is lookin mighty fine.. and its fresh with 36k on it.
I'm in the Collision Biz so I deal with Salvage Yards every day there are some great deals out there, your right you just have to look, and know what your looking at, I've built some pretty good combos from boneyard parts and have spent a lot less money on my builds because of it and make plenty of power..
Here are two informative links
http://en.wikipedia.org/wiki/GM_Vortec_engine
http://www.fbparts.com/ls_general_charts.htm
Old Dec 28, 2009 | 07:35 PM
  #55
omc8's Avatar
Yes look for 07 and later 5.3s have these and 05-07 L-33 vin B ext cab 4x4 trucks.The L-33 used both 243 and 799 , again these are pretty much the same head.Some early 06 vettes got 799 heads, but most were 243s. 243s first appeared on 01 LS6. One advantage the old 706 and 862s have is their combustion chamber is only 61cc so that will help you get the bump in compression you want.And these heads are cheap and plentiful.
Old Jan 9, 2010 | 02:03 PM
  #56
battsup's Avatar
Went today to go pick up what I was told was an aluminum 5.3l out of an '06, thought it was going to be a L33. The engine turned out to be Iron block. It's an '06 with 706 heads on it and fly by wire throttlebody. The guy also has an '02 with 862 heads on it. My research shows they are basically the same heads and that GM just changed the part# somewhere down the road and that the 706 also have some sort of triangle something or other on the outside.
The guy wanted 1000 each, then dropped them down to 850, he said he wants to get 750 for them each. I checked car-part.com and a 5.3l engine is about 2000-2500 around here, its ridiculous.
The '02 has manual fan on it and has 77,600 miles on it. The '06 doesn't have the manual fan and has 108,700 miles on it. I already bought an LS1 intake, rails, injectors and will be needing to use a cable TB which makes me lean towards the '02 but i'm unsure if its worth buying that old of an engine. What are the differences between the 02 and the newer 06 engines? I remember reading that older engines had piston slap on start up and that this was no longer the case on newer engines.
Old Jan 10, 2010 | 01:14 AM
  #57
brian g's Avatar
keep looking, I just saw an ad for a long block 5.3 for 350$-which means you could prob get it for 250.
Where are you that they want 2000-2500 for a 5.3?!?!?!
Old Jan 10, 2010 | 01:32 AM
  #58
battsup's Avatar
Vancouver, BC. Everything in Canada costs more. Trust me I've been searching everywhere in the local area(300 miles). You must have missed my transmission search. It took me 2.5 months before I found a 2wd 4l60e and it was 4.5 hours away and across the border! All that we seem to have up here are 4x4 tranmissions. The junk yards wanted $2000. I ended up lucking out and getting one last weekend out of a 2003 Savana for $500. With the prices they ask for 5.3's i'm afraid to ask how much they'd want for a 6.0!
Old Jan 12, 2010 | 07:06 PM
  #59
omc8's Avatar
I would look for a 07 and later to get the good heads or a L33, keep looking there better deals out there.You may have to go a distance or pay shipping from the lower 48.But there are a bunch of 5.3s out there ,thats in your favor keep looking.
Old Jan 12, 2010 | 08:32 PM
  #60
JohnFrazee02SS's Avatar
I got one with 67k and 862 heads for $550. I wanted the iron block, so I am happy.
